Fuel return plumbing question?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by flc120, Jan 5, 2013.
  1. flc120
    flc120 Heavy Load Member
    916
    122
    Jul 11, 2012
    Miami,FL (yeah i know :( )
    Well in my thread posted regarding moving my tanks back and adding toolboxes i already mounted the pass side fuel tank, which no leaves me to now start to connecct all lines to the pass side tank and take off the driver tank to start working on it as well.
    heres my issue regarding the feed line i have none pretty simple i just needed to extend line a couple more feet and connect to other tanks. NOW my issue is the RETURN line on the driver side tank it had a bung a the top of the tank for the return line BUT my PASS side new tank doesnt have a bung it just has the sump section on bottom of tank with the 4 half inch ports on the bottom one of these being for the feed line.
    MY QUESTION is can i run the return line to one of these port on the bottom of the tank which would be below the fuel level or would i be able to maybe tee it off of the FEED line? this is only a temp fix until i can remount the driver side tank which has the port on it for the return.
    I ask as the newer freightliner tanks have the fittings which hookup to the middle of the tank which then feed from tubes on the inside which go back down to the bottom of tank to pull and dump fuel whcih then in turn with this type of system leave the fuel returning to the bottom of the tank. I just wanted to know if i would have any issues with aeration or pressure or just plain any...i just need to get her hooked up to start pulling fuel out of the new tank so thati cna get ot working on the driver side tank. Doesthe return line on diesel mechanical system need to be plumbed above fuel level line or does it even matter. Hopefully i can just plumb it to one of the bottom three ports of tank for now.
    any help with this would be great im trying to get all this done and her running off new pass side tank before i start the week so any help would be great.\
    my only other cheap and simple alternative would be to drill and tap a fitting to an old fuel cap i have add a barbed fitting and some 3/8" transmission hose and just drop return fuel in from top of fuel cap. not to bad of a mission for me as i dont have to make new lines and its going to be cheaper plus theres no pressure on that side so a hose a clamps will work. Will Goodyear rubber hitemp transmission hose work well with diesel fuel i know in terms of temps i will be fine but will the diesel fuel mush up the hose and make it soft if i use transmission hose? i like this idea just unsure about hose.
  3. Semi Crazy
    Semi Crazy Road Train Member
    3,033
    2,044
    May 13, 2011
    Middle Tennessee
    It wouldn't matter. Splashing down from above will aerate your fuel so if return comes in below fuel level is actually better.
  4. truckmechanic
    truckmechanic Medium Load Member
    534
    140
    Jan 14, 2012
    Hi Desert Ca
    Run it right next to the feed line it will be fine,I would steer clear of the rubber hose and clamps dot wount like it and plus not worth the risk,make sure to put shut off valves in the tank outlets just in case you lose a line down the road.
  5. flc120
    916
    122
    Jul 11, 2012
    perfect thats all i wanted to know... i will run it to the port on bottom of the tank next to the feed line. the rubber hose and clamps idea was just a thought.
  6. flc120
    916
    122
    Jul 11, 2012
    quick question? what would be the problem of teeing off the supply feed line going to the motor and just adding the return to it, to then avoid having to run an extra line back to the tank? what would be wrong in doing it like this in turn it would be the same as if it was sucking it from bottom of tank just with less the fuel hoses needed. Plus the unburnt fuel will always get used and never need to be drawn back to tank similar to the way older carb systems work with no need for return line.
  7. CatPowerC15
    CatPowerC15 Medium Load Member
    347
    90
    Feb 18, 2010
    Siler City, NC
    Hot fuel and poor performance will result. You need to run the return to the tank.
  8. flc120
    916
    122
    Jul 11, 2012
    isnt the hot return side of the fuel dumping into the tank thus making the smae fuel thats being pulled from the supply line just as hot as the return side of fuel? What could the temp difference be in 8' more of fuel line????
  9. truckmechanic
    534
    140
    Jan 14, 2012
    Hi Desert Ca
    The tank acts kinda like a fuel cooler while driving down the road teeing off might cause a problem of there is a air pocket in the return line or by there being more pressure on the return line then the suction line
  10. flc120
    916
    122
    Jul 11, 2012
    understood but isnt the return line pressureless? sorry for being so hard on this i just want to get down the concept of why not.
  11. Semi Crazy
    3,033
    2,044
    May 13, 2011
    Middle Tennessee
    It has some pressurization from the transfer pump constantly pushing fuel through the pump. The plungers pressurize the nozzle lines. I'd say return has the same pressure as inlet.
    Warmed fuel is better to mix in the tanks to cool itself down/warm the remaining fuel.
    And the virtually closed loop you would create would severely hamper the ability to pull from the tank.
    The supply from the tank will have a pressure and suction at the same point. Totally bad idea.
