Fuel pump bad, fuel module showing metal
Discussion in 'Ask An Owner Operator' started by Transportacion R&R, Jul 8, 2020.
  1. Transportacion R&R
    Transportacion R&R Light Load Member
    175
    73
    Apr 10, 2020
    NewWell they are saying the fuel pump needs to be replaced as well as the fuel module. Which is fine but then they want to drop the tanks and clean out the tanks and make sure no metal is in the tanks and making it through to the new pump and fuel module. If they drop the tanks it’s a $9200 hit. I’m wondering if I can get away with just replacing the fuel pump and the fuel module. Keep in mind the check engine light came on and westopped the truck within 100 miles at the weyer cavelocation in VA. Excel truck group. What to do.....
  3. Hulld
    Hulld Road Train Member
    2,882
    6,564
    Oct 19, 2015
    Upstate NY
    What engine?
  4. bigdad7
    bigdad7 Road Train Member
    1,837
    1,364
    Jun 6, 2010
    ks
    Prob need the whole system flushed my dd13 did that 40 miles out had metal throughout you will be lucky if it's not in the injectors
  5. Transportacion R&R
    175
    73
    Apr 10, 2020
    Its just horrible that you get a check engine light code, you run a bit and the damage is already done. Definitely will be changing out Fuel pumps often from now on. your better off.
  6. Transportacion R&R
    175
    73
    Apr 10, 2020
    What did the fix cost you if you dont mind me asking. I got them down to $7800, flushing the whole fuel system, cleaning out the tanks, replacing the fuel pump, fuel module, etc. What hurts the most is being stuck in the mountains of VA while the repairs are being done. I should be out of here by Tuesday they said.
  7. bigdad7
    1,837
    1,364
    Jun 6, 2010
    ks
    Not sure it was still under extended warranty ....was up there rho
  8. Transportacion R&R
    175
    73
    Apr 10, 2020
    $7800 out the door, fuel pump, dropped the tanks, cleaned out the tanks, replaced fuel lines, fuel module, etc.. these fuel pumps are horrible.
    D.Tibbitt Thanks this.
  9. mitmaks
    mitmaks Road Train Member
    2,543
    2,065
    May 16, 2014
    Which engine/truck?
  10. Mattmanstroked
    Mattmanstroked Light Load Member
    185
    278
    Nov 24, 2019
    On a Cummins ISX 15 fuel pump can take out the engine. Now that's what I call bad.
  11. Transportacion R&R
    175
    73
    Apr 10, 2020
    The great thing about Detroit DD13/15, the metal has a hard time getting into the engine to destroy the truck completely. One of the main reasons i didnt go with Cummins.
