Fuel Mileage W990's
Discussion in 'Kenworth Forum' started by andrewsdad, Dec 21, 2020.
  1. andrewsdad
    andrewsdad Light Load Member
    71
    206
    Jul 18, 2016
    What type of fuel mileage are you getting on your W990s? We're only getting 5.5 and 5.7, we only have 2 of them. Hauling van trailers from ON - South East and back every week. Light loads around 30K down, and probably 1/2 that on the way back north.
    Would have expected better mileage than that for newer trucks.
    Seem reasonable or a bit light on the MPG?
    Kevin.
  3. Tb0n3
    Tb0n3 Road Train Member
    4,278
    8,194
    Oct 5, 2012
    Earth
    What engine, rear end, transmission?
  4. Roberts450
    Roberts450 Road Train Member
    2,237
    3,635
    Feb 6, 2016
    The wheelbase will effect it too. @andrewsdad throw us a picture to see the setup, but if you guys where after MPG numbers you shoulda gotten 680’s or 880’s not the 990.
    Soltaker and bzinger Thank this.
  5. AModelCat
    154,214
    The 990 isn't exactly aerodynamic. Its probably better than a 900 but its still got a big, flat front grill.
    bzinger and Caterpillar Cowboy Thank this.
  6. diamondd817
    diamondd817 Light Load Member
    159
    560
    Oct 11, 2020
    What tires do you have? Tire rolling resistance can make a big difference in fuel mileage.
    Tb0n3 Thanks this.
  7. Numb
    Numb Crusty Curmudgeon
    3,934
    8,733
    Jan 30, 2012
    Charlotte, N.Carolina
    coming down through WV?
    they have some steep climbs.
  8. Rubber duck kw
    6,092
    17,685
    Dec 9, 2017
    That's ridiculous. For all the modification they made to the classic W9 look for those they should be doing 7.
    Vampire and w9l Thank this.
  9. Laszlo
    Laszlo Bobtail Member
    6
    Dec 5, 2020
    I don’t know much about the newer trucks, but if you using those red filters( Baldwin) that would likely be the problem
  10. larry2903
    larry2903 Heavy Load Member
    788
    988
    Oct 18, 2009
    On the trails
    I have a 2020 W990 put in service June 2019 that has a lifetime average of 7 on the ECM with 190,000 mls on the odometer, pump to pump average for 2019 was 6.8, 2020 has not been totaled yet but should be in the same neighborhood. I do have an APU that gets plenty of usage and usually run the speed limit up to 70 mph.
    When I ordered this truck I did spec it out to be economic.
    Paccar MX13 455 HP multi torque 1550/1750 split
    Paccar 12 spd auto shift
    2.79 rears
    264” wheel base
    I do run 445 50 22.5 super single tires, not because I believe they increase mpg’s much but the weight savings between truck and trailer allows me to scale 47,700 lbs. I live on the western slope of the Colorado Rocky Mountains and being able to scale that amount of weight sometimes helps me be able to get out of the house easier.
    My previous truck was a T660 ordered with similar specs,
    Paccar MX13 445 HP 1650 torque
    Eaton 13 spd ultra shift
    3.09 rears
    Same tires, I don’t remember what the ECM lifetime average was but pump to pump for the four and a half years I owned it was 6.8. The last 2 years i owned the 660 it was pulling the same trailer I pull now, 53’ flat with a Quick Draw tarp system on it. I have been pleasantly surprised by the mpg’s with my W990.
    Pulling the weight you are, I would think your mpg’s would be better but there are a few things you didn’t tell us. Do the trucks have APU’s, if not that could be the reason for the mileage you’re seeing, how many miles on the units, how long is the wheel base? When were they put in service?
    I would like to know the specs and when they were put in service.
    bzinger Thanks this.
  11. andrewsdad
    71
    206
    Jul 18, 2016
    I can't find the exact build sheets that we got when we got these spec'd. We didn't go with the automatic transmission, and went with a manual. I'll have to check the rear end we got in them too. Decent wheelbase as well, again not 100% sure on the exact measurements. Both trucks do have APU's though. These were put into service, around a year or so ago and both have only +/- 136000 miles. I'll have to dig into finding more specs for you.
    I was able to check the idle times on the trucks for the month of November, one used 14 gallons and the other used 16 for the month. Not excessive in my mind, traffic stoppage, waiting for customs, waiting in line for fuel, and even the odd dock that would be in and out situation.
    Speeds seem to average 65-70 MPH, same driving habits as they had with their old trucks before we decided to upgrade to these one.
    larry2903 and bzinger Thank this.
