Fuel lines.
Discussion in 'Trucks [ Eighteen Wheelers ]' started by spyder7723, Apr 20, 2017.
  1. spyder7723
    spyder7723 Road Train Member
    15,467
    25,009
    Mar 31, 2013
    sarasota, fl
    So all my fuel lines are seeping. Cant complain they are the original lines on an 03 so they've done their job butt its time to retire them.
    My question is about replacing them with plastic. I've got the reinforced river lubes but i see quite a few trucks with a plastic line that resembles at first glance a half inch air line. Is there any benefit to using plastic vs the steel braided rubber? Is it simply that the plastic is cheaper?
    Oh in case it matters, its an 03 columbia with a 12.7.
  3. Blackshack46
    Blackshack46 Road Train Member
    Well steel braided is that way for strength. The last thing you want is a line breaking and fueling laying on a hot block.... are you sure the plastic wasnt just a coating, with the actual line inside? Doesnt fuel eat plastic over time?
  4. spyder7723
    15,467
    25,009
    Mar 31, 2013
    sarasota, fl
    It may not have been actual plastic, but is some type of similar man made composite material. And im sure it wasn't a coating, the ones I've seen they are transparent, you can see the fuel going through them.
    Im probably just gonna replace them with whats on there, but wanted to find out the reason some trucks come with plastic. And others experience with them.
  5. Dave_in_AZ
    369,995
    To line the pockets of the manufacturer why else? There is a guy on here someplace, maybe it's in LiveTrucking with a Detroit rant that is epic. It's all about how he loves / swears by his Detroit, but all the plastic peripheral parts break that Freightliner uses.
    BoxCarKidd and lilillill Thank this.
  6. sealevel
    sealevel Road Train Member
    2,664
    10,282
    May 31, 2012
    U.S. 41
    I have the hard plastic lines on my 06 Columbia. My understanding is that the advantage over the older style lines is they won't internally swell over time and restrict fuel flow or internally deteriorate. The hard plastic will get hairline cracks with age that are hard to find so they have to be replaced too. I have heard of some guys swearing by replacing them all with standard hydrolic hose. Makes sense to me.
    spyder7723 Thanks this.
  7. lilillill
    lilillill Sarcasm... it's not just for breakfast
    5,642
    13,470
    Nov 7, 2007
    Possum Booger, Alabama
    I'm pretty sure the reason you never saw as many truck fires back in the day was because the fuel lines were made of metal, not plastic.
    Mine has plastic but if I was to replace them, it would be hard line and braided stainless.
  8. 062
    062 Road Train Member
    6,143
    33,159
    Oct 20, 2013
    I could see a benefit with a clear line in certain places. Where I get hoses made uses Parker 201-8 haven't had a problem yet,it seems to stay flexible longer than hoses made at napa,but don't remember part number of the napa hose.
  9. Tug Toy
    Tug Toy Road Train Member
    6,932
    72,425
    Jul 4, 2015
    Corn field
    I would not use stainless braid. The newer cloth or plastics covered stuff I s just as good for this application in my opinion. That stainless will rub a hole in anything within an inch of it. Including steel frames.
    spyder7723 and BoxCarKidd Thank this.
  10. SheepDog
    SheepDog Road Train Member
    3,481
    2,084
    Nov 30, 2008
    Sand Lake, MI
    I am looking for help on the fuel line fittings my 84 International 9670 has. The mail fitting is cone shaped and when I tighten up the female part of it, coming from the actual fuel line, the whole line turns when I get close to the end. Hope I make sense
