Fuel line typ and size?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Volvo8873, Mar 25, 2017.
  1. Volvo8873
    Volvo8873 Light Load Member
    239
    145
    Apr 27, 2016
    Western Wisconsin
    What will work when in comes to fuel line? Dealership has the synflex plastic line and fleet pride has the heavy duty stiff rubber line with steel reinforcement along with crimped fittings.
    I'm guessing the standard 1/2 I.d. automotive line rubber fuel line with screw type clamps and brass nipples will not the work?
    Thanks
    Al
  3. xsetra
    xsetra Road Train Member
    5,092
    6,939
    Aug 21, 2011
    The fuel line on my truck has Number 8 fittings for the supply line and Number 10 for the return lines. They have the crimped ends on the line.
    I would think as long as the line can handle the pressure and volume of fuel they should work. Just need to get proper fittings to adapt.
    Good luck.
  4. DL550CAT
    DL550CAT Road Train Member
    1,427
    1,482
    Oct 18, 2009
    Waynesburg, Pa
    Nope and nope. The larger fuel is not under pressure but is a suction line. A regular fuel hose would collapse.
    Roger McG and xsetra Thank this.
  5. Ezrider_48501
    3,845
    5,130
    Apr 2, 2011
    bismarck, nd
    whenever i have needed replacement fuel lines on a big truck i just had some replacements made up with hydraulic hose
    snowman_w900 and Volvo8873 Thank this.
  6. xsetra
    5,092
    6,939
    Aug 21, 2011
    That hose is great for everything. Air, fuel, coolant. Seems to be highly resistant to abrasion also.
  7. Volvo8873
    239
    145
    Apr 27, 2016
    Western Wisconsin
    I'm liking this a lot more as it is cheaper and more durable. My parts guys has it in 1/2 and 3/4 double steel braided. Did you use the 3/4 for the intake or is that over kill? Thanks
  8. Ezrider_48501
    3,845
    5,130
    Apr 2, 2011
    bismarck, nd
    3/4 is a pretty darn large hose i would not think original is any bigger than 1/2 or maybe 5/8, normally what i do is i take the hose off and run it down to napa or another hydraulic place i use and just have them make a hose that matches the old one, same length size and end fittings.
    most original hoses iv come across have been originally whats called "truck hose" or "transport hose". with the screw on taper style fittings, you can buy everything you need to make new hoses with that as well and make them yourself. i like the hydraulic hose because its a much tougher hoses. and i like the crimp fittings better than the screw on style.
    you could also use an hose. if you felt so inclined but i would guess cost would be more than hydraulic.
    Volvo8873 Thanks this.
  9. Volvo8873
    239
    145
    Apr 27, 2016
    Western Wisconsin
    I gotta give it to you I never would've thought to use hydraulic hose. Got some half-inch made up last night and got them attached it is so nice. I had to use a plastic fuel line from the Davco to the primary fuel filter housing because of the strange OEM fitting cannot convert over to 1/2 NPT.
    15ft hydraulic line with swivel ends
    158.00
    Bronze 1/2 3 way
    5.50
    Like I said I couldn't use the hydraulic line because of the OEM Voss fitting on the primary fuel filter housing. It was some special 17 mm metric thread I believe. Got screwed by Volvo and was charged $98 for 7.5 ft and 2 Voss fittings. Ridiculous
    snowman_w900 and Ezrider_48501 Thank this.
