Fuel line replacement
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Luwi67, Dec 12, 2013.
  1. Luwi67
    Luwi67 Heavy Load Member
    746
    484
    Oct 24, 2012
    Long island
    Hey guys,
    I have to change the fuel lines in my 97 379, I was wondering if anyone has come across an alternative to the standard rubber line say, a more durable longer lasting material. Been reading a lot here about fuel line related problems and, I've seen the mention of a line "upgrade" that is impervious to microbes but, no source.
    I've been poking around the marine forums but still no luck. Any help to point me in a direction would be appreciated
  3. KC Guardrail
    KC Guardrail Light Load Member
    199
    155
    Dec 7, 2013
    Stainless steel would be the way to go. You would have to fabricate your own fittings, but it is possible.
    Luwi67 Thanks this.
  4. Luwi67
    746
    484
    Oct 24, 2012
    Long island
    The suction side fuel lines is what I need to replace soon, do you mean braided stainless steel?
  5. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    on European trucks they use plastic lines, like air lines. I'd say plastic line is better, more durable
    Luwi67 Thanks this.
  6. vangtransport
    vangtransport Heavy Load Member
    863
    2,837
    Apr 14, 2009
    Some Volvo's use plastic as well. I agree they are allot better!!
    Luwi67 Thanks this.
  7. puncher
    puncher Medium Load Member
    540
    358
    Feb 12, 2010
    Tn.
    With all the bio blends out there I got nervous, I went to a local hose specialty shop and found they had some synthetic hose that supposedly is resistant to chemicals and the bio-diesel. I paid something like just under $400 for just hose and fittings, and then you will have a labor charge if you don't do it yourself.
    Luwi67 and wore out Thank this.
  8. JohnP3
    JohnP3 Road Train Member
    1,594
    683
    Feb 21, 2010
    Rock Creek B.C. Canada
    Plastic is the best, fittings are easy to get hose is cheap and available, anywhere, it is very tough. I slide on sections of heater hose, to protect it where you are going to clamp or tie it.
    I have seen units with Teflon hoses, great, But if you have a problem on the road where do you find a replacement?
    Just a thought!
    puncher and Luwi67 Thank this.
  9. puncher
    540
    358
    Feb 12, 2010
    Tn.
    I may have messed up going the route I went, plastic is easy to work with like you said John, and definitely cheaper.
    Luwi67 Thanks this.
  10. Luwi67
    746
    484
    Oct 24, 2012
    Long island
    Plastic meaning like the Dorman nylon fuel line? What type of fittings do you use with that?
    I was looking at the Trident Barrier Lined fuel hose, it has a nylon barrier inside to keep the fuel from contacting the rubber so I guess you wouldn't have to deal with the hose deteriorating in the future, I like that idea.
    The Peterbilt has I think JIC fittings either 37° or 45°, what type of fittings do the trucks with plastic line use?
  11. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,211
    Jan 7, 2013
    Synflex hose is really good. It's the plastic stuff, similar to plastic air lines.
    http://www.eaton.com/ecm/groups/public/@pub/@eaton/@hyd/documents/content/pll_1173.pdf
    We use it on all our replacements. It's great stuff, but it must be routed and secured good. It is not nearly as resistant to chaffing as braided hose. It also can be warmed up with a heat gun and formed to help hump it over or under frames and cross members (don't get it too hot though). The fittings are barbed fittings, the tubing just pushes on, no clamps or crimps. Once it's on, it's really on. You'll have to cut it or heat it to get it off, either way, you ruin the end of tubing getting it off.
    The hose does fit DOT compression fittings too for an emergency roadside repair, just in case. We had a Pete once that had a big strap break off the frame that was holding all the hoses and wiring along the frame. It rubbed a hole in an air line an a fuel line. Road service was able to put in compression fittings to get him going and back to our shop for a new fuel line.
