Fuel injector of the cylinder 6 code
Discussion in 'Volvo Forum' started by Hburg, Nov 19, 2022.
  1. Hburg
    Hburg Bobtail Member
    6
    Hi everyone
    I just had my all 6 injectors&cups replaced at some mechanic for my 2015 Volvo vnl
    And after driving for like 1000 miles this code came
    Sa 16 DTC P02D700 Fault Code
    I looked it up online and it says my
    Fuel injector of the cylinder 6 - determination of
    the correction at the maximum limit
    Does anyone know whats the problem or if it happened to someone
  3. Jacoooooooo
    Jacoooooooo Heavy Load Member
    742
    1,049
    Oct 20, 2013
    In my case this code meant I had to replace the injector. Code kept coming back and at one point injector completely froze. Replaced with good used one and do far so good, if next one goes kabum will replace them all.
    You say you had injectors replaced though, with new ones? May be a faulty injector, probably has an electrical issue.
    Hburg and Siinman Thank this.
  4. Siinman
    Siinman Road Train Member
    5,160
    12,933
    Mar 5, 2017
    Kansas City, MO.
    Have the guy fix your truck. Sounds like you either got bad part or the guy does not know what he is doing.
    Hburg Thanks this.
  5. nasriza
    nasriza Road Train Member
    2,397
    2,070
    Feb 1, 2013
    Chicago, IL
    First whoever installed the injectors needs to put in the calibration codes in the ecm, after this the injector has to be adjusted properly and then if code still pops up you have a bad injector.
