Fuel injection timing on a 3406-E or C15\C16 Cat
Discussion in 'Trucks [ Eighteen Wheelers ]' started by PROSTREET80, Jul 27, 2012.
  1. PROSTREET80
    PROSTREET80 Light Load Member
    75
    13
    Jul 11, 2012
    northwest AR
    I know that different programs and uprates change the fuel timing and alot of other things dealing with performance.
    What I have never really understood is how do the different programs actually change the injection timing on these engines.
    I can see how it can change pulse width, and the timing of the fuel entering into the injector body itself from the solonids controlled by the ECM.
    but the actuall injection timing is fixed thats when it is misted into the cylinder because it is all gear timed in the gear trane of the front of the engine. When I think of changing actuall injection timing I think of changing the mist timing of the injector popet in relavance to a certain degree of the piston position before Top Dead Center (BTDC) Say like 30 degrees BTDC to say Like 35 BTDC or somthing like that as an example.
    I know by the electronic changes these programs make it does change or change somthing because of how it effects performance but I don't understand how it does that much to the performance when the mechanical injector that is worked by the injector cam is gonna spray at a certain degree of the pistion travel BTDC each time, no matter how long or what time that fuel inters into that injector body from the controlling of its solonoid.
    The mechanical crank and injector cam timing that sets the piston position and the injector firing position is the same each time the engine goes through its four strokes so how does this settup really control the injection timing of the fuel into the cylinder. All I see that The ECM and injector solonoids, can control is the injector fuel timing and not the injection timing into the cylinders and I just don't see how the injector fuel timing changes performance of the engine when the fuel is sprayed into the cylinder at the same piston position every time. It should be misting it at the same place every time on that compression stroke. Can someone explain this one aspect of this engine to me. Im just curious.
  3. Far_Call
    Far_Call Medium Load Member
    453
    416
    Aug 21, 2009
    Australia
    The injector fires when the ECM tells it to not when the Cam tells it to so another words the injector is travelling through its stroke long before the ECM tells it to fire. the PW will control the duration of injection which will never be as much as the cam can actually deliver.
    To look at it another way the cam may travel 10 or 15% or even more % before the ECM takes part and depending on Rack travel & PW as to what % it continues to inject. Under full noise and full load you might find depending on the Engine rating that you are only using 30, 40, 50, 60% of the mechanical cam.
    If you consider the injector plunger movement it is stop start.. at both ends of its travel. It cant instantly build internal pressure and cant miraculously travel its full lift at a constant velocity so it will start slowly and accelerate to its max velocity and then slow to a stop and then return to its rest position. Having the Plunger in motion prior to the ECM playing its roll will reduce the time in ms for it to reach a pressure internally to be able to lift the needle to start injection.
    Buckshot7cz, 2bit, C16KIWI and 7 others Thank this.
  4. speedyc-16
    speedyc-16 Light Load Member
    92
    6
    Sep 6, 2009
    ice box,idaho
    Can a person advance the cam gear a tooth on a 5ek,6nz or a 7cz and gain anything that way Far_call
  5. ROBSREDFORD
    ROBSREDFORD Light Load Member
    266
    139
    Sep 2, 2008
    MIDLAND, NC
    Will sure sound good .... Dunno if helps never dyno'd ....2ws and later gotta unplug crank sensor.....
  6. Far_Call
    453
    416
    Aug 21, 2009
    Australia
    The Timing wheel is integrated into the Camshaft Gear and as such if you alter the timing by way of advancing or retarding the Camshaft hear you will also alter the Intake and exhaust timing.
    On the older 5ek Types you only had one engine speed/timing sensor but with all later engines you have two so you have the added problem of the two coming out of sync if you try and advance the Cam gear.
    This is all simply done in the ECM Tables and that's what the ECM is for. Sadly there isn't a lot of people who can manipulate these tables with a degree of professionalism required. Lots of people say they can but in my experiences there is only a few people with a small amount of knowledge that they get by with. When it comes to the nitty gritty they all seem to fall over.
    Driveit and beltrans Thank this.
  7. Gear head
    Gear head Medium Load Member
    532
    91
    Apr 1, 2012
    Belair,md
    The injector lobe is only to add lots of pressure to injector. It multiplies the 90 to 100 psi from fuel pump to thousands of psi. Computer controls the rest. Based on throttle position engine position and speed . Plus many more.
  8. Mr. Haney
    Mr. Haney Road Train Member
    2,693
    2,040
    Dec 17, 2008
    You're talking over 99% of the peoples head Greg LOL
    To put it in simple terms the the injector body is full of fuel all the time and has free fuel flow to the fuel rail no matter where the plunger is traveling in the barrel of the injector in relationship to the cam lobe. The electronic solenoid controls a door that traps the fuel in the injector body. Once the fuel is trapped it is only a matter of milliseconds before the pressure rises high enough to pop the tip open mechanically.
    Altering the flash file by adding timing in the timing tables changes the activation of the solenoid. This changes when the door closes to the fuel rail and the following pressure rise internally in the injector body to open the tip.
    Most people think the solenoid fires the injector. The solenoid closes the door to keep the fuel from escaping the injector body back into the fuel rail in the cylinder head that is its only job in layman terms. Fuel travels in both directions from the injector body to the fuel rail this is what most people never understand.
  9. Far_Call
    453
    416
    Aug 21, 2009
    Australia
    The milliseconds you mentioned to raise the pressure Kurt high enough to pop the tip open is proportional to the plunger velocity and degree of Crankshaft rotation matched to the Camshaft Ramp rate and Rocker Ratio ramping along with Engine RPM influencing the plunger velocity altering the Milliseconds to which it needs to open the door. When plotted correctly the ECM gives you the ability to utilise this rise in plunger Velocity by way of altering the timing at any given RPM to the degrees of Crank rotation to maximise Fuel burn, Horse Power and timing over many varying combinations of Rpm and Boost.
    Something you cant do with any Mechanical setup.
  10. Mr. Haney
    2,693
    2,040
    Dec 17, 2008
    OMG...........you did that on purpose!!!!!! ROFLMAO
  11. morehp
    morehp Medium Load Member
    699
    206
    Jun 18, 2012
    Far call do you know and or have mutch to do with neil at advanced diesel??
