14l detroit. Has green antifreeze in it and clear with yellow tint liquid that smells like diesel in over flow tank. Can diesel get into the cooling system?
Fuel In radiator? Can diesel get into the coolant system?
Discussion in 'Freightliner Forum' started by jsnell, Oct 26, 2017.
As I Never opened up an engine myself..(Done everything else) I Think diesel can get into the cooling system with leaky O-rings on injectors- Probably other ways too that im not sure of
Thank you stayinback Yep I thought injectors but have never had it happen. Do you know how to test for this
stayinback Thanks this. -
No I Do not..But there are many on here that can assist better than me, Who are actual mechanics
jsnell Thanks this. -
Injector cups
peterbilt_2005, bzinger, Mattflat362 and 1 other person Thank this. -
Thank you baha. No heater lines in tanks.
Thank you CleverNDGuy that's what I think but I want to know for sure -
Got green antifreeze dripping out of a heater line and the clear yellow diesel smelling liquid in fill tank. I don't know how unless diesel is lighter than antifreeze
The injector cups are stainless steel and rarely to they cavitate like the old copper ones. It is going to be the injector cup o rings. You need a special tool and a lot of patience to do this job properly.
