Not a cummins owner, but I have the same issue (volvo)
Changed out the fuel pump - thinking it was the problem. That did not solve it.
Thought it was injector seals....but when we took the top cover off, did pressure test...we found a crack in the head (along a fuel supply line). The head has internal channels to deliver the fuel.
Put everything on the table, and start eliminating them as you go.
FUEL IN OIL 2010 CUMMINS ISC 8.3
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Kawi027, Feb 22, 2018.
Page 2 of 17
ISC only has return rail in head.
nax Thanks this. -
Can you clarify please? -
@spsauerland Oh. my bad. I was not "questioning " your statement.
It was more of curiousity on my end, since right at the back of the head, is my return line too, and it's near cyl/injector # 5....where the crack is.
Your explanation of the high pressure (supply side) vs. low(er?) pressure on return helped.
I'm trying to understand the root cause of my truck's heads crack, so that I don't end up with the same issues (on a new head), should there be other triggers that I have not thought about.Kawi027 Thanks this. -
Dyeing the fuel is an excellent idea also. I've never seen a pump or injectors leak like that on this engine ,but surely could be a possibility.Kawi027 Thanks this. -
We have had fuel pumps leak internally to the engine.
I just checked the dipstick this morning and its about 1/2 inch above the full line (oil capacity on this engine is about 5 gallons. I changed the oil on Monday and got the level perfectly on the full line. Havnt hooked up insite yet, will do that later today. I have a friend with a spare fuel pump that I may try swapping out this weekend and see if that takes care of the leak.
A side note: we had a 3 week stretch recently that the fan clutch was partially on all the time due to a slight air leak going to the fan clutch causing it to partially engage through out the day. While it was doing this the engine temp stayed between 160-175degrees. Now that we repaired the air leak the temp stays above 180 and goes to 200 then fan engages and cools to 180. I wanted to put this out there as it may have something do to with the regen process having difficulties during that time due to engine temp being so low. -
DOCs do no last forever and degrade over time. This results in incomplete burns and soot loading in the DPF. DOC and DPF need to be remove and cleaned periodically as regular maintenance. I would do this first. If problems continue after that and you still have the original DOC, I would say it has come to the end of it's life.
Page 2 of 17
