fuel haulers, need help with tare weight
Discussion in 'Ask An Owner Operator' started by tank319, Jul 12, 2015.
  1. tank319
    tank319 Bobtail Member
    17
    Jul 12, 2015
    Going to start a new gig pulling tankers. I have to be able to carry at least 8600 gallons i believe. Anyways, here is my question. The company requires tare weight to be under 16k pounds including driver. Im looking for a flat top with a small sleeper, so my question is, what is the heaviest i could be on the tare weight? How much do trailers usually weight?
    Please share your experiences and what you haul, what you weight empty and how much you can load (diesel or gas) to drive legal (80k)? Thanks in advance!
  3. baha
    baha Road Train Member
    4,137
    2,835
    Jul 25, 2013
    ga
    9 or 10 speeds weigh less than 13 or 18 speeds, small fuel tanks help little, smaller eng. will be ness. older tanker co. liked M-11 cumm. eng. alot for weight saving, just drive to nearest scale on the test drive you will take all the trucks on an comp. weights with same truck with diff. eng. look close at tag inside door or in dash box for weight stamped on plate and what it wt. on scale?
  4. Ezrider_48501
    3,845
    5,130
    Apr 2, 2011
    bismarck, nd
    my mack cx 613 70" sleeper with the e7 460 engine and 13 speed was just a bit over 16k from the factory 19,600 now with pto wet kit steerable lift axle ect added to the truck
  5. rank
    rank Road Train Member
    9,916
    113,498
    Feb 11, 2010
    That's for sure. At least 1,000 lbs on a T800 vs a T660 ISX and a T2000 Accert. Bad news is it's over the steers so you need your fifth wheel to be set up correctly to take advantage of that weight. The set back axle of the T800 helps you get weight up there. You would never get it to work on a hood.
  6. daf105paccar
    6,564
    7,293
    Apr 15, 2012
    OP
    buying new or used?
  7. tank319
    17
    Jul 12, 2015
    Sorry for the late reply folks. I have set on a truck and picking it up this Wednesday. Got a deal on a 2010 Pete 384, cummins ISM 410hp, 10 speed, it has 15180 stamp weight and 15400 at scale with driver inside. Everything is fine as far specs on the truck and the work I'll be doing, I just have second thoughts on that small ISM 410 since I was originally looking for the ISX.
    Do you guys have any experience with these engines?
    baha Thanks this.
