Fuel Filters
Discussion in 'Peterbilt Forum' started by awright, Dec 20, 2016.
  1. awright
    awright Light Load Member
    86
    15
    Dec 20, 2016
    I have a Cat C15 625hp in my 2006 peterbilt 379. I am running a Bully Dog system with single turbo conversion. I seem to always be changing my cat fuel/h2o filter (256-8753). Am i trying to get too much fuel through this filter for the high horsepower or what? I had this problem prior to installing the single turbo/bully dog kit. I just wanted to put all info on the table to see if anyone has any suggestions. I was told today at peterbilt that there is a high flow base made by caterpillar to replace the factory fleetguard filter base. I brought the new one home, and I looks identical to what I have, so mine must already be the high flow. Should I be looking into the fuel pump?
    Any ideas are welcome.
  3. blairandgretchen
    13,238
    70,566
    Dec 9, 2011
    South west Missouri
    Are you saying you're changing the filter often because it is plugged, and the engine runs fine after you change filters?
  4. awright
    86
    15
    Dec 20, 2016
    Seems to! I am wondering if I need to go to a bigger micron filter, but dont want to have other problems down the line either. I especially have problems with fuel at Loves in Dwight IL. I dont get far down the road and my fuel filter guage is in the red, and time for filters again. I have talked to Manager, and even talked to Headquarters in OK City. They claim I am the only one having problems.
    KB3MMX Thanks this.
  5. HalpinUout
    HalpinUout Road Train Member
    7,074
    18,159
    Oct 2, 2011
    Theirs threads on here with othere who have experienced issues with fuel from Loves as well.
  6. blairandgretchen
    13,238
    70,566
    Dec 9, 2011
    South west Missouri
    I'm thinking - that there's a fuel purity problem, have you shone a flashlight in your tanks to check for algae? And/or cut your filter open to inspect?
    awright Thanks this.
  7. 062
    062 Road Train Member
    6,144
    33,186
    Oct 20, 2013
    After the truck has been parked for a few hours drain some fuel into a clear container,preferably glass. Drain each tank into a separate container,let them set a while. Could be you have crud in the bottom of the tanks that gets stirred up when you fuel.
  8. KB3MMX
    KB3MMX Road Train Member
    3,069
    2,588
    Dec 29, 2014
    Orrstown, PA
    Your filters are working correctly , stopping contamination before it goes to the really expensive parts.
    Do NOT go to a larger micron filter .... Clean your fuel system and keep changing filters
    AModelCat Thanks this.
  9. little cat 500
    2,044
    1,090
    Jan 17, 2010
    Abbottstown PA
    bigger the micron the bigger the junk going thou the injectors
    KB3MMX and AModelCat Thank this.
  10. AModelCat
    154,582
    Couldn't you install your 2nd filter base and plumb them together in parallel? Double the filtering capacity and increase the fuel flow through the filters. Hitachi did that with their newer large sized excavators.
  11. 25(2)+2
    18,749
    45,388
    Sep 18, 2006
    the road less travelled
    They used to plumb Stanadyne square base glass enclosed filters in multiples, the other way is what Davco did with higher capacity like the 482 series I have on the DD15, which is in addition to the engine mounted filters, they plan on changing them at every other full pm (oil and filter change) roughly 100 thousand miles, and when used as a secondary filter, probably run larger micron filtering.
