Fuel filter wrench size.?
Discussion in 'Experienced Truckers' Advice' started by pete159, Oct 28, 2020.
  1. pete159
    pete159 Light Load Member
    104
    67
    Dec 6, 2008
    mississauga
    Greetings.
    Last winter i gelled up, again, and long story short it's no fun.
    This winter if it happens again I want to be able to change my fuel filter.
    I have a cummins isx15 with a davco filter. The filter part number is fs19765.
    What size wrench do I need to take it apart. Is an adjustable wrench a better idea?
    Any tips for doing this what I hope is a simple test....edit.....i found it.
  3. sealevel
    sealevel Road Train Member
    2,664
    10,282
    May 31, 2012
    U.S. 41
    It takes a Davco wrench. Can pick it up at almost any TA. Just slides over the housing and grips the notches on the collar and WHALLA!
    KB3MMX and D.Tibbitt Thank this.
  4. kylefitzy
    kylefitzy Road Train Member
    4,597
    18,983
    Aug 12, 2007
    Kansas city,Mo
    Get the proper wrench. They are cheap compared to breaking the locking collar or cracking the fuel bowl. Both of which will result in a road call. 09DD6596-916B-4352-87E3-0B9858DAE6E9.png
  5. Dockbumper
    Dockbumper Road Train Member
    3,778
    9,860
    Apr 29, 2020
    Make sure to keep your fuel treated with ANTI GEL is the best advice I have
    Swine hauler and D.Tibbitt Thank this.
  6. KB3MMX
    KB3MMX Road Train Member
    3,069
    2,588
    Dec 29, 2014
    Orrstown, PA
    You really need to add the coolant heat option to the bottom of your davco
    kylefitzy Thanks this.
  7. 201
    201 Road Train Member
    12,052
    24,606
    Apr 16, 2014
    high plains colorado
    The Binford 9000 Channellock fits all,,
    Final Drive, D.Tibbitt and Kyle G. Thank this.
  8. mustang190
    mustang190 Road Train Member
    2,827
    6,064
    Jan 18, 2011
    Florida Panhandle
    Don’t go north of I20?:):):)
  9. snowwy
    snowwy Road Train Member
    20,527
    13,262
    Jul 6, 2009
    If you're going to the cold. Fuel up with cold.
    Don't fuel up in Texas expecting to be Allright in the Dakotas. I made thst mistake in Wyoming.
    And. As mentioned. Anti gel.
  10. Elroythekid
    Elroythekid Road Train Member
    2,604
    5,655
    Sep 9, 2010
    Halifax Nova Scotia
    I run Canada down south and return all winter EVERY WINTER. I always fill in Blacksburg SC and head north. It will get me back into Ontatio no sweat. BUT. Before I park on night 2 in Ontario, I fill with northern fuel. I've never had to add antigel ever, just buy your fuel up north and you will be fine.
    AModelCat Thanks this.
