Fuel filter restriction 6NZ
Discussion in 'Trucks [ Eighteen Wheelers ]' started by mtoo, Nov 7, 2015.
  1. mtoo
    mtoo Road Train Member
    1,942
    4,529
    Jan 15, 2011
    Retired on bended knee
    On my old B model I would change the frame mounted filter when it pulled about 8 inches vacuum. Since a C15 6NZ pumps so much more fuel and returns much more with a completely different type of pump.
    So I am wondering how much fuel restriction, do you guys with C15 pull on a fuel restriction gauge before you change the fuel/water separator filter?
  3. rollin coal
    rollin coal Road Train Member
    13,913
    28,979
    Mar 29, 2008
    TN
    I never see any restriction on that gauge. I clean the screen in my primary every time I change the oil and toss/replace the secondary then too - at or a little before every 12,000 miles.
    mtoo Thanks this.
  4. mtoo
    1,942
    4,529
    Jan 15, 2011
    81 views on this post. Your the only answer RC. I wasn't sure they still used the screen when they built the 6NZ. Not much old school Cat info on this forum any more. A few years ago there was more Cat info than on here than one could digest.
    Cottonmouth85 Thanks this.
  5. rollin coal
    13,913
    28,979
    Mar 29, 2008
    TN
    Yeah I know it went down hill in a big kind of way a few years ago when they banned tuning talk.
    Weekend's can be slow maybe by Monday afternoon you might get some more comments. And there's still some good mechanics posting helpful general info in here from time to time also.
    Mine is MBN in an 03 truck. Some people have told me that screen filter was old school and you don't really see them on trucks as new as mine.
    KB3MMX and Cottonmouth85 Thank this.
  6. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,737
    Jan 30, 2010
    keep stroking.
    screen filter maybe old school but one of the best IMO. I use a carquest hydro filter with 10 micron. only pull about a 4 on my restriction gauge when on a hard pull.
    BoxCarKidd and mtoo Thank this.
  7. T800H
    T800H Medium Load Member
    608
    298
    Apr 2, 2010
    The Keys
    I hardly ever see any restriction on my fuel gauge, I replace all my filters at oil change, 8k to 10k miles.
    which filters do you use?
    I'm currently running Cats for the first time and so far so good 256-8753 on the frame and 1R0749 on fuel block.
    I had to go to Pete dealer and since I was there picked up two more sets and my sales guy told me never to use two Cats at the same time and suggested FS1212, so I got one to try next.
    I don't see any more restriction than before Cats, actually less than ever before, but to be honest I have replaced the entire fuel delivery system and bored the new fuel block except the return, all new fittings are bored too, with all bigger lines, so waiting to see when I replace the fuel water sep with FS1212 if there is even more flow thru.
  8. Superhauler
    12,209
    100,737
    Jan 30, 2010
    keep stroking.
    749 cat on the fuel block and 33339 carquest on frame.
  9. T800H
    608
    298
    Apr 2, 2010
    The Keys
    I went looking for carquest 33339 and found WIX 33339, here are the details
    "PARTS DETAIL
    Principal Application: IHC, Dresser, Galion, Komatsu (Primary) (32 Micron)
    Style: Spin-On Fuel Filter
    Service: Fuel
    Media: Paper
    Height: 6.987
    Outer Diameter Top: 3.674
    Outer Diameter Bottom: Closed
    Thread Size: 1-14
    Burst Pressure-PSI: 315
    Max Flow Rate: 12-15 GPM
    Nominal Micron Rating: 32"
  10. Superhauler
    12,209
    100,737
    Jan 30, 2010
    keep stroking.
    that's it I think I quoted it was a 10 mic. I was wrong. they did change back to wix.
  11. T800H
    608
    298
    Apr 2, 2010
    The Keys
    Re reading your question I never gave you a good answer.
    I see any where from 2 to 3, 3.5, but unless I get any trash at the pump, it stays pretty much the same when they get replaced.
