Fuel filter Microns
Discussion in 'Trucks [ Eighteen Wheelers ]' started by rank, Dec 21, 2017.
Page 1 of 5
Does this help at all? It’s from FASS’s page.
Replacement Filters - Fassriderank Thanks this. -
Avg filter is 10 micron. Any smaller and you restrict flow.
rank Thanks this. -
Bigger engines may be different though....rank Thanks this. -
My supplier switched to Baldwin a while back and I’ve been noticing a restriction on the gauge. Thought it might be the filter
Good link - thanks Mack!
I run the south a lot and down there a lot of the fuel is b20 biodiesel blend and I'm lucky to get 4000 miles and my Davco filter is all the way to the top.
I use the Detroit brand fuel filters.rank Thanks this. -
The Cat filter on the motor lasts between oil changes usually (18,000). If I notice my fuel pressure creeping a little too high, I change it a bit earlier.
Page 1 of 5
