Fuel filter. Do I need to change it? DD15
Discussion in 'Freightliner Forum' started by joseph1853, Oct 16, 2021.
  1. joseph1853
    joseph1853 Road Train Member
    1,003
    562
    Dec 12, 2010
    Waco, TX
    So I drained the fluid out of my fuel filter yesterday and decided to check it again after running it an hour later and the filter was filled back up to around the middle which is where it was before? Does this mean the filter is at the end of its life? I haven't had this truck for very long and am not sure when it's been replaced last.
    D.Tibbitt and truckdriver31 Thank this.
  3. Short Fuse EOD
    2,786
    8,738
    Jul 29, 2015
    Midwest
    Should be a line on bulb indicating when to change filter. My davco has this. Higher the level the sooner to replace. You may also check your fuel restriction gauge as well to aid you. - Unsure if cascadia has this gauge… one bad batch of fuel can expedite your level in the bulb!
  4. truckdriver31
    6,998
    8,358
    Sep 18, 2013
    fueling at the loves will expedite the filter too
    msh, joseph1853 and D.Tibbitt Thank this.
  5. InTooDeep
    4,981
    37,363
    Jan 17, 2016
    Carmichael CA
    Mine always runs just below half with new filter DD15
  6. uncleal13
    uncleal13 Road Train Member
    3,797
    6,296
    Apr 9, 2009
    Humboldt, Sk
    When the level gets up to the black line at top of filter, then it is time to change.
    Sometimes that can take a few years. So I change it annually at the latest.
    msh, joseph1853 and truckdriver31 Thank this.
  7. Short Fuse EOD
    2,786
    8,738
    Jul 29, 2015
    Midwest
    Wow, I change that feller about every 32k.
  8. joseph1853
    1,003
    562
    Dec 12, 2010
    Waco, TX
    Oh great, that's the only place I fuel. I get the best discount there through Comdata.
    truckdriver31 Thanks this.
  9. joseph1853
    1,003
    562
    Dec 12, 2010
    Waco, TX
    That's where it was on mine. I've not seen it any higher than that so far. It's just seemed odd that I would drain it and then almost immediately it went back to that spot. How often do you drain yours? I heard Jason pope say he does his every day? Thought that was a bit excessive.
  10. truckdriver31
    6,998
    8,358
    Sep 18, 2013
    c
    cleans the system great tho
    joseph1853 Thanks this.
  11. InTooDeep
    4,981
    37,363
    Jan 17, 2016
    Carmichael CA
    I don't ever drain it till filter change. If there isn't any fuel in there you would be sucking air. Had the Oring slip once changing filter and it wouldn't run for #### and had to prime it ever time to start
    D.Tibbitt and joseph1853 Thank this.
