fuel cooler?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by 05379, Jan 30, 2009.
  1. 05379
    05379 Light Load Member
    115
    Nov 15, 2008
    montague ma
    i was thinking of installing a fuel cooler on my 05 pete with the acert who has done it and is it worth it? thanks
  3. Rock hauler
    Rock hauler Light Load Member
    264
    54
    Nov 26, 2008
    Deridder La.
    A lot of the new pete's already have fuel coolers. look between the rt fuel tank and drive shaft.
  4. 05379
    115
    Nov 15, 2008
    montague ma
    of coarse mine doesn't:biggrin_2552:
  5. Jas
    Jas Medium Load Member
    If it doesn't have one its definately worth fitting, the fuel system helps cool the injectors in hot weather, the cooler the injectors run the longer they will last. If you add a cooler and a fuel wire you will see a good gain in horsepower also.
  6. 05379
    115
    Nov 15, 2008
    montague ma
    thanks i have the fuel wire just gotta add the cooler
  7. pullingtrucker
    pullingtrucker Road Train Member
    1,185
    598
    Dec 21, 2008
    Fostoria, Ohio
    I'm installing one on my Pete when it gets warmer. I just have to find a place to fit it that suits me. I'm really considering putting a little cooling fan on it to, just to keep the air moving when I'm sitting still.
  8. coalhauler625
    coalhauler625 Light Load Member
    96
    12
    Jan 6, 2009
    somewhere in VA,KY or WV
    where can i find one of these coolers
  9. Rock hauler
    264
    54
    Nov 26, 2008
    Deridder La.
    I think there less than $200 at peterbilt, bought mine off ebay for 50. goes in the return line on new truck
  10. pullingtrucker
    1,185
    598
    Dec 21, 2008
    Fostoria, Ohio
    You can buy them out of Summit or Jegs racing cataloges also. Just remeber which ever you buy it has to be strong to handle all the road abuse. I'm gonna go ahead and install a bypass line for in the winter or if the cooler springs a leak...cheap insurance you know.
  11. DD14
    DD14 Light Load Member
    177
    32
    Jan 21, 2009
    Ontario
    Why couldn't you put the cooler after the feul pump (mounted in front of the rad.)sending the cooler feul through the secondary filter and then straight into the head.My KW had a cooler mounted out front from the factory but the feul after being cooled goes back to the feul tanks.
