Fuel consumption vnl d13
Discussion in 'Volvo Forum' started by Milan700, Jan 23, 2020.
  1. Milan700
    Milan700 Bobtail Member
    Hello to all.
    I have 2014 volvo vnl 740
    It has I shift 2,64 ratio 430hp. Xe
    My fuel consumption right now is around 5.3 mpg
    Before was around 6mpg
    I change injectors 150 000 miles also was around 6mpg from first day.
    What can be a problem
  3. Socal Xpress
    1,855
    1,958
    Dec 6, 2014
    Los Angeles, Ca
  4. Milan700
    I am pulling flatbed. So it's ok to be around 6.5 mpg. But not under.
  5. Freightliner Classic
    Freightliner Classic Light Load Member
    108
    98
    Dec 17, 2018
    Rome GA
    look did u put a bigger set of injectors in or the same. They are rubber orings on them they could be leaking
  6. Milan700
    Unfortunately I didn't do that by myself because I didn't have tools to perform that.
    Truck dont have power.
    Using fuel more than any other truck what I have. I am desperate. Idk what to do. And I am scared to go in shop because they will start changing parts and that will take me nowhere
  7. I glide 47
    I glide 47 Road Train Member
    1,426
    1,523
    Jun 3, 2017
    Fuel mileage goes down in the winter cold air is harder to drive thru ,winter blend fuels grease and oils are thickened idle time increases !
  8. Socal Xpress
    1,855
    1,958
    Dec 6, 2014
    Los Angeles, Ca
    Now I have never heard or seen the Dealer offering bigger injectors for the D13 motor but would be interested in seeing if that was even an option.
    Also only seen the D13 hopped up to 550hp and 1900tq but again maybe someone has done more
  9. 05vnl670
    05vnl670 Light Load Member
    165
    60
    Feb 17, 2013
    When you drive and is under 35 deg outside does your engine temperature go below 170?
  10. Socal Xpress
    1,855
    1,958
    Dec 6, 2014
    Los Angeles, Ca
    Curious on where this would go. Can you explain?
  11. 05vnl670
    165
    60
    Feb 17, 2013
    I had a bad thermostat mine temperature was going down to 130. Engine is not running efficiently at this temperature and the ECU is shooting fuel to warm up the engine.
    Newto Trucking Thanks this.
