Fuel consumption calculation
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by DUNE-T, Jan 7, 2021.
  1. DUNE-T
    DUNE-T Road Train Member
    6,881
    16,626
    May 10, 2015
    Detroit, MI
    My truck's fuel consumption calculator is completely off, it's like 1mpg less vs manual calculation.
    How exactly does truck's computer calculate mpg, so I can start figuring out what's wrong?
    The engine is pre egr 12.7 Detroit in a Volvo 770
  3. lester
    2,915
    7,846
    Jan 2, 2012
    NW, Iowa
    I assume it estimates how much fuel its squinting out each time an injection fires and based of speedometer makes the calculations.
    Wouldn't think there's much you could do to make it more accurate unless your speedometer is off but then your calculation would be off to.
  4. DUNE-T
    6,881
    16,626
    May 10, 2015
    Detroit, MI
    I wonder if this truck has injectors problems. I just put a new bigger turbo and instead of getting better mpg, it's actually getting worse, plus the computer readout is off on top of that
  5. uncleal13
    uncleal13 Road Train Member
    3,797
    6,293
    Apr 9, 2009
    Humboldt, Sk
    Don’t worry about the computer being off . It doesn’t actually measure the fuel flow. It is just an estimate. Some trucks are close, many can be out 20% or more.
    Pen and paper is the only accurate calculation.
  6. AKDoug
    AKDoug Medium Load Member
    323
    801
    Mar 21, 2018
    I have a brand new 2021 that's off all the time. If you idle much, or do a lot of city trucking it gets even worse. The only way to really measure is to hand calculate it when you fill up.
    Just slapping a new bigger turbo on the engine is not going to necessarily increase mileage. There has to be tuning to go with it in the ECM. If that wasn't done correctly, the inputs the fuel mileage readout uses to display the mileage may be off by quite a bit.
    BoxCarKidd and lester Thank this.
  7. DUNE-T
    6,881
    16,626
    May 10, 2015
    Detroit, MI
    The hp was increased from 430 to 500 and a bigger turbo was installed to properly handle the extra power.
    Something is off and I am not sure what yet.
    I always do hand calculation and my other the same model trucks are usually close to what computer shows, but this one is just way off and that bothers me.
  8. Dave_in_AZ
    370,741
    Is it calculating in the fuel used at idle? It doesn't take much idling to knock the mileage way down.
  9. DUNE-T
    6,881
    16,626
    May 10, 2015
    Detroit, MI
    When measuring mpg, I don't idle at all.
    When I purposely leave it idling, the computer shows 0.2 gal/hr, while my other trucks show 0.7-0.8.
    Something is definitely not right with this truck's computer
    Dave_in_AZ Thanks this.
  10. Rideandrepair
    17,224
    55,904
    Aug 8, 2015
    My 99 Classic had the Detroit dash computer on it. It always read higher than actual. I heard it was based on RPM readings. Don’t really know how it works. I used it to refine driving habits. What I noticed is the higher the computer went, the more it lied. 7.5 was actually 7. 8.5 was 7.75, 10 was 9. I hauled very light loads, and got amazing fuel economy. It was a pre Lo Nox engine. It was interesting for a while. But got tiresome. Finally just started running it how I wanted to. Mileage settled in at around 6-6.5 for the life of the Truck.
