Front End Making Popping sounds when make hard r turn
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Gram25, Oct 23, 2015.
  1. Gram25
    Gram25 Bobtail Member
    21
    Oct 23, 2015
    I know there is another thread about this same thing but it is old and I don't know if anyone still reads it.
    We have the same exact problem with our truck. We have a 2007 Volvo 780. My husband has been all under our truck checking everything out.. Nothing is loose.
    We just had new king pins and bushings installed. Maybe 6 months ago. Just a couple weeks ago we had had it in the shop in Texas and had the whole spring system replaced. we picked it up and went to try it out, When I turned right back into the dealership it popped again. The truck does ride better because the springs were worn out but evidently that was not what caused our problem. We have looked, pulled prodded on everything under out truck trying to make sure nothing was loose. The steering box, the motor mounts, anything my husband can think of .. we have checked.
    We drove it yesterday to see if it was still popping, (we are at home right now. ) and it is still doing it.. We went into an abandoned subdivision and rode around swerving from the left to the right.. It pops really loud when we swerve left. He took the shocks off of it and we are going to drive it without them to see if it may be the shocks.
    Does ANYONE have any suggestions?
  3. windsmith
    windsmith Road Train Member
    7,296
    6,031
    Sep 2, 2011
    NEPA
    Leaf spring hanger and / or pivot bushings are worn.
    Edit: I see that you had the springs replaced, but the symptom you describe is usually related to the spring bushings. Were the frame brackets replaced also?
    OLDSKOOLERnWV and Gram25 Thank this.
  4. mountaingote
    mountaingote Road Train Member
    2,026
    7,916
    Sep 22, 2012
    Almost any spring setup will pop turning corners, just the nature of the beast as the weight shifts. You surely don't want to drive it without shocks
  5. Gram25
    21
    Oct 23, 2015
    We just had Leaf spring hangers on both sides of the truck installed 3 weeks ago. We had new air bag and leveling valve installed on right side of truck also. We have put cab air bags and shocks on .
  6. Gram25
    21
    Oct 23, 2015
    We were only going to try it in the streets behind our home.. We only took them off to see if it's still popping.. If it doesn't pop without shocks I guess it could be that.
  7. Gram25
    21
    Oct 23, 2015
    oh, we have owned this truck for 7 years and it has just started this popping thing in the last couple months.
  8. mountaingote
    2,026
    7,916
    Sep 22, 2012
    Check the u-bolts too just to make sure. Sounds like you covered most of the possibilities. Only other thing I can suggest is check out the steering components
  9. Oscar the KW
    Oscar the KW Going Tarpless
    12,246
    28,114
    May 19, 2011
    What about the shackle pins and bushings?
    OLDSKOOLERnWV Thanks this.
  10. gunner76
    gunner76 Medium Load Member
    500
    137
    Mar 11, 2010
    IA
    did you check the cab mounts? I had one go bad and it would pop when I turned sharp enough to make the cab shift.
  11. A21CAV
    A21CAV Road Train Member
    1,848
    2,156
    Oct 4, 2011
    Laredo, TX
    My Prostar did that backing up and full lock turn . It was a bent steering stop bolt. Not a Volvo but something else to look at .
