Front differential front pinion seal leaking
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Edjahman, Sep 2, 2018.
  1. Edjahman
    Edjahman Medium Load Member
    648
    444
    Apr 2, 2013
    Would it be OK to run a leaky pinion seal for a couple days?
    It's wet on the outside of the housing on the front but it's not leaking really bad.
    Thank you.
  3. daf105paccar
    6,564
    7,293
    Apr 15, 2012
    Depends on why it started leaking.
    Option 1 is the seal just went bad.
    Option 2 is that inside something is breaking which put to much pressure on the seal so it started to leak.
    Edjahman Thanks this.
  4. Steamnsteel
    Steamnsteel Bobtail Member
    39
    30
    Jan 19, 2016
    Try spraying it with regular WD-40, this will cause it to swell a little and buy you a some time before replacement. This trick does work in most instances unless you have something worn so much it is getting ready to fly apart.
    BoxCarKidd and Edjahman Thank this.
  5. Edjahman
    648
    444
    Apr 2, 2013
  6. Edjahman
    648
    444
    Apr 2, 2013
    I'll try the wd 40 trick. Thank you! I've never heard that one yet!
    I appreciate your replies!
  7. Edjahman
    648
    444
    Apr 2, 2013
    It's only making a pretty small mess at the moment.
  8. pushbroom
    pushbroom Road Train Member
    1,777
    7,253
    Sep 1, 2012
    Monitor it. Once it starts puking and covering your diff deal with it.
    If you check your fluid level that will give an indication of how much its loosing.
    SAR, spsauerland, Oxbow and 2 others Thank this.
  9. Goodysnap
    Goodysnap Road Train Member
    3,694
    8,948
    Jul 12, 2017
    Check the input for slop indicating a more serious internal issue, bearing failure or the like. If movement is found I say tear into it before more damage is done. Like pushbroom says if it's just a seal, check the oil level and monitor.
    Listen for the air puff or build of pressure to leak out when pulling the fill plug. If so the vent is clogged and pressure is pushing the oil out. Who knows cleaning the vent may stop the leak. Seen it before.
    Tug Toy, SAR, spsauerland and 3 others Thank this.
  10. Edjahman
    648
    444
    Apr 2, 2013
    Thank you! I'll try those other suggestions also!
  11. Edjahman
    648
    444
    Apr 2, 2013
    Thank you! It actually quit leaking, it looks like!
    Oxbow Thanks this.
