Front axle on tandem
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by biggi1996, Jun 7, 2021.
  1. biggi1996
    biggi1996 Light Load Member
    120
    13
    Dec 10, 2014
    Can anyone tell me what my problem may be. I have a freightliner century and when I put it in gear the rear axle turns but the other axle doesn't and the truck will not move.
  3. Judge
    84,390
    Does locking in power divider help?
    Rear axle is the pull axle, unless you lock in the divider, I’d say the rear end went out, you can limp it to a shop if you have a power divider lock
  4. biggi1996
    120
    13
    Dec 10, 2014
    I engaged power divider and nothing happened.
  5. Judge
    84,390
    Not good.
    Could be through shaft.
    Big Road Skateboard Thanks this.
  6. lester
    2,914
    7,842
    Jan 2, 2012
    NW, Iowa
    There is no "pull axle"
    Stray_Dog Thanks this.
  7. Judge
    84,390
    Unless it’s a tag axle, there is is, one pulls, one rides along unless power divider is put on, then locks both axles to “pull”
  8. AModelCat
    154,240
    Both axles drive all the time. Locking in the power divider just means both axles are forced to turn together at the same speed.
    Unlocked its a balancing act between all 4 wheel ends. Lose traction on one or break a component and you lose that balance and now you sit.
  9. Judge
    84,390
    Why your crazy.
    If you ever get that rear axle over a hole/high center, that rear axle will turn and spin in the air.
    Locking the power divider, allows other axle to pull.
    If not, you are stuck, get a wrecker, or a flatbedder with a chain.
    I figure it’s a broke axle.
    But maybe, by some thoughts it’ll end up he just has a flat.
  10. lester
    2,914
    7,842
    Jan 2, 2012
    NW, Iowa
    No way, no how. A normal tandem axle truck with power divider unlocked any of the 4 wheel ends can be powered. As A model cat said, all things equal all 4 wheels will receive power. Once ANY of the 4 wheel ends looses traction I will spin.
    Jack up any corner of your drive axles and put truck in gear, that wheel in the air will spin. Set it down and jack up a different end and it will spin. Do it with all 5 wheel ends and the one in the air will spin every time
    Stray_Dog and AModelCat Thank this.
  11. lester
    2,914
    7,842
    Jan 2, 2012
    NW, Iowa
    Same thing happens if the front axle leaves the ground. It will sit and spin until you lock the power divider
