Fridge for Kenworth W900
Discussion in 'Trucker Forum Classifieds & Trading Post' started by TheLoadOut, May 5, 2022.
  1. TheLoadOut
    TheLoadOut Road Train Member
    2,138
    10,048
    Nov 6, 2019
    Purchased a new fridge for my W9 right before I decided to remodel the sleeper, as a result I don't need the fridge I purchased. It was used on 2 trips and still looks like it just came out of the box. Located in southern Utah, if interested message me.
    This fridge will fit MOST 1999 and newer W9, T600, T660 and T800 trucks and connects to the wiring in your truck using an optional power connector.
    NOTE: Cabinet depth MUST be a minimum of 18” on both sides to install this fridge. This can be an issue in some of the KW cabinets.
    • Asking $550.00
    • Built-in, silent, highly efficient, fan cooled 12vDC SECOP (Formerly Danfoss) BD35F-HD compressor.
    • No power inverter necessary! Connects to the 12v factory fridge wiring in most trucks by using optional available connectors.
    • Proven design as used in many OEM trucks.
    • Solid mounting prevents part movement for quiet operation.
    • 12-volt draws only 6 amps on a 15 amp circuit.
    • Built-in low voltage cut-out and overvoltage protection.
    • Insulation is high density, CFC-free polyurethane foam.
    • Replaceable gloss black door panel and reversible door hinge location.
    • Door latch provides positive closure.
    • Fridge liner is made from thermoformed plastic for easy clean up.
    • Interior LED light.
    • Adjustable electromechanical temperature control.
    • Forced air fin and tube condenser for optimal performance.
    • Average consumption: 40 amps/24hrs at 75° F ambient with an internal temperature of 36° F.
    • Weight: 37 lbs
    • Perfect Condition 0321221536.jpg 0321221536a.jpg 0321221535_HDR.jpg 0321221535b.jpg RF3.jpg RF4.jpg
    Volume (CU ft/Liters) 1.73/49
    Dimensions HxWxD (inches) 20 1/2 x15 x 17 1/2
    Power consumption (W/24h) 278
    Weight (lbs) 37
  3. krupa530
    krupa530 Light Load Member
    295
    1,134
    Dec 3, 2014
    Orem, UT
    What you doing for the remodel ace.
  4. Tug Toy
    Tug Toy Road Train Member
    6,932
    72,425
    Jul 4, 2015
    Corn field
    Where is it at?
    TheLoadOut Thanks this.
  5. spindrift
    spindrift Road Train Member
    3,233
    12,905
    Dec 2, 2014
    Texas
    Southern Utah...
  6. TheLoadOut
    2,138
    10,048
    Nov 6, 2019
    St. George, Utah to be exact. Cheaper than the dealer and Truck Fridge, perfect condition.
  7. TheLoadOut
    2,138
    10,048
    Nov 6, 2019
    It's still available
  8. TheLoadOut
    2,138
    10,048
    Nov 6, 2019
  9. TheLoadOut
    2,138
    10,048
    Nov 6, 2019
    Still have the fridge for sale as well as some KW VIT interior pieces, along with screws and buttons. They will work on any 72 inch KW sleeper, adding that "Seattle Package" look to your sleeper interior.
    Fridge $550.00
    Interior pieces $1,200.00 (color:grey)
    Located in St. George, Utah
  10. 94RK
    94RK Bobtail Member
    5
    Do you still have the refrigerator?
  11. TheLoadOut
    2,138
    10,048
    Nov 6, 2019
    No, sorry, it has been sold
