I am looking to add a potable water holding tank to my W900L. I drink reverse osmosis water which I produce at home, and it is getting really old filling up jugs for my trips. So I figured I would see if anyone has some ideas for adding a water storage tank to the truck. I would like to maybe put it under the bunk so it doesn't freeze in the winter, and plumb a small 12v pump system on it. Any ideas where I could find a hard tank (not a bladder) and the gear to do this? It'd be nice if the pump also works in reverse so I can fill the tank without trying to pour it in and spill it all over the bunk heater, etc.
40 gals. would be great. I drink about a gallon a day so that would be plenty for drinking and cooking while out for 3-4 weeks.
I wonder if an RV store could install one for me?
Thanks for any ideas.
Fresh Water Holding Tank?
Discussion in 'Ask An Owner Operator' started by VisionLogistics, Aug 3, 2012.
RV shop likely could do it or check out a boat supplie shop , large pleasure craft have same setup your looking for
VisionLogistics Thanks this. -
I've been looking at 12 volt pumps for pumping fresh water through a water filter. Check this one out:
http://www.google.com/products/cata...=X&ei=Qr_UT5brMoXJ0AGE7rSSAw&ved=0CLcBEPMCMAQVisionLogistics Thanks this. -
I wonder if those flojets have a decent warranty. I'll check with a local RV store or boat supply and see if they can do it, that way I'll have a point of contact for warranty issues if needed.
Looks like this tank will fit in the channel at the rear of the bunk storage and might even slide in and out via the side box doors.
http://www.plastic-mart.com/product/565/32-gallon-rv-water-tank-rv69w
32 gals, and since there is a 12v dc bus already under there it should wire up pretty easily. Just need to figure out how to fill it. -
And that helps me. I've been thinking about a tank that I can use my high end water filter with. This one with the bus is a good solution. -
a section of pvc pipe with end caps will hold water too
Volvo 780's have a sink option that comes with a tank with pump, and a different tank (smaller) to catch from the drain. You might be able to find one of these used. But with mine, they do freeze in extreme cold weather in the side box location, and I don't know if underbunk in a KW would be significantly bettter.
Whatever implemented has to be properly vented and ask around to RV owners how many holding tanks have been ruptured during the fill process (over-filled with 85 psi water source) Just make sure the water level can be easily monitored from outside the truck during fill.
RO water will quickly take on any plastic odor and taste from a plastic storage tank. (easier and quicker than carbon filtered, deionized water)VisionLogistics Thanks this. -
Oh Vito I was talking about the DC bus already under the bunk, not already on the tank.
STexan thanks for pointing out the odor issue. I usually transfer the water into milk jugs and haven't noticed a taste, but I wonder if the new plastic tank will be different. Maybe if I pre-treat the water with some baking soda to balance the PH, it might also help the odor?
