Freon charge for 2001 sterling 9500 day cab
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by jazzedman, Sep 17, 2021.
  1. jazzedman
    jazzedman Bobtail Member
    38
    8
    Feb 15, 2019
    We've got a 2001 sterling 9500 day cab with a remote mount condenser in the shop, that I'm needing the freon charge amount. I pulled out 4.450lbs. I'm pretty sure that's way too much, there is no info label in the normal places that you would see. I put in 3lbs (which I found on line, but was for a 2018 I think), but it's freezing up. it takes about a 1/2 hr but it eventually makes it back to the compressor. Any help would be greatly appreciated.
  3. bad-luck
    bad-luck Road Train Member
    3,245
    5,943
    Nov 16, 2013
    Baltimore, Maryland
    Try calling Bay Shore Ford In New Castle, De They are a Heavy Truck Dealer 302-656-3160 they may be able to answer your question.
  4. p608
    p608 Road Train Member
    2,181
    2,991
    Nov 10, 2016
    did you change the dryer?
  5. BoxCarKidd
    BoxCarKidd Road Train Member
    4,418
    6,431
    Aug 26, 2014
    It is 9:41 PM. Get it worked out? If not still around?
  6. MRMTRANS
    MRMTRANS Medium Load Member
    334
    372
    Apr 28, 2015
    Put some guages to it. I think 280-300 on the high side, and 140-160 on the low side are the ranges you want. If all good, then I think moisture could be a problem
  7. jazzedman
    38
    8
    Feb 15, 2019
    Evidently the customer is going to have the place that installed the remote mount condenser figure it out. I guess they were having issues before and had ANOTHER shop look at it and they bypassed the low pressure switch at the accumulator due to the fact that there is one down at the remote mount con.
    So, out of our hands now. Thanks for all the replies!
