Freightliner Wheel Fitment Help
Discussion in 'Trucks [ Eighteen Wheelers ]' started by jsnap, Mar 19, 2010.
  1. jsnap
    jsnap Light Load Member
    77
    7
    Apr 10, 2008
    ststen island NY
    Hi fellas can you tell me if 22.5 rims that came of an m2 112 will fit on an Fld 120 thanks. Richie
  3. Les2
    Les2 Road Train Member
    5,150
    2,288
    Jul 25, 2008
    kicked back in my lazyboy...
    As long as they have the same hub, 10 hole or 8 hole.
  4. mslashbar
    mslashbar Medium Load Member
    599
    802
    Jul 22, 2009
    elizabeth,co
    There is a difference between the hub piloted wheels and the stud piloted wheels. They would both have to be the same to switch. The newer stuff all has hub piloted wheels, the old stuff stud piloted.
  5. Polarbear
    Polarbear Light Load Member
    151
    92
    Nov 30, 2007
    USA
    As long as they have the same number of lug holes and are also matchn with where they are piloted.
  6. jsnap
    77
    7
    Apr 10, 2008
    ststen island NY
    They are both 10 lug thats all I know and my FLD is a 95
  7. Longhood379
    Longhood379 Medium Load Member
    389
    125
    Nov 30, 2009
    Cremona AB
    Hub piloted wheels have metric studs and the front wheel nuts & studs look the same as the back . stud piloted wheels have a square head on an inner nut on the back . hub pilots also have a flanged nut and stud pilots have a tapered nut.
    If your not sure take them to a tire shop:biggrin_25520:
  8. RW.
    RW. Heavy Load Member
    715
    995
    Jan 18, 2009
    west central IL
    The stud piloted, or ball seat rims' bolt holes will have a taper on each side of the hole where the nut fits in to locate the wheel. Hub piloted wheels have plain bolt holes, no taper. If your truck has hub pilot wheels, the nuts will have a built in washer on the back of the nut, flange nut. The two different kinds are NOT interchangeable.
