freightliner spring and shackles
Discussion in 'Trucks [ Eighteen Wheelers ]' started by earthmover, Jul 1, 2011.
  1. earthmover
    earthmover Medium Load Member
    563
    20
    Jan 27, 2009
    castalia , north carolina
    well just got my truck back today after a week..dump truck was ridein pretty bad and had a bounce at about 35mph so i took it to the shop to get it checked out......bad spring bushing and pin was what we thought....no no on bad spring ,bushing, and hanger on the back of the leaf... freightliner wanted 500.00 per side just for the hanger... i called around and found a aftermarket comp. for 310.00 for both sides had to ship 2 days .. well all the parts fit and back going and saved some money truck rides great and cant tell the spring hangers and stuff was replaced in the front unless you know its not bounceing at 35mph......i had bought pins and bushing from freighliner beforer i kinew the hanger was bad cost me 210.00 took them back and got a refund and got the kit above for 310.00 now thats both sides of the back spring incl. hangers,pins,andbushing,and shackles with shim,and nuts and bolts....thought i would let you guys know..ill post the name of the comp. if any 1 need it thanks mike
  3. AUSSIE DAVE
    AUSSIE DAVE Road Train Member
    1,032
    176
    Feb 21, 2010
    OZ - Brisbane
    yep pays to shop around, my last saving was a airbag, kenworth wanted $330 for 1 k303-18 i got the exact same airbag for $171 (both are firestone part number wo###17)
  4. heavyhaulerss
    3,723
    2,040
    Dec 23, 2009
    AL/TN BORDER
    did you replace the steer hangers or the drives ?
  5. heavyhaulerss
    3,723
    2,040
    Dec 23, 2009
    AL/TN BORDER
    I am having mine done in the next month or so. send me a p.m. on the co info, please. thanks'
  6. earthmover
    563
    20
    Jan 27, 2009
    i replaced the steer hangers only the back of the steer ...the shop checked the front hanger on the drive and they was good to go...the back hangers had froozen up in the bushing and was popping ...the shop said someone had replaced them before and didnt shim them right..cause you get alot of shims to get a tight fit....truck rides good now no popping and also replaced 1 u joint at the back of the trans it had slack in it from the bearing eating in the joint it self.....dont know how that happen i grease the truck every 2 weeks (dump) and more often it in rough work...but i just thought i would let you guys know about the freightliner parts and price and that the other company is alot cheaper...if anybody else need the info i'll be glad to pass it on ...i would post it but dont think i can be in line with the board rules...thanks mike
  7. heavyhaulerss
    3,723
    2,040
    Dec 23, 2009
    AL/TN BORDER
    then p.m. me with the info. thank you.
  8. heavyhaulerss
    3,723
    2,040
    Dec 23, 2009
    AL/TN BORDER
    never mind. did not look at my inbox before posting this. I need my coffee!:biggrin_25511:
  9. earthmover
    563
    20
    Jan 27, 2009
    no problem heavyhaulers:biggrin_2559:
  10. Dcdjmd
    Dcdjmd Bobtail Member
    Va.
    Could you post the name, address, or web address of that company you used to save money. We have a Freightliner also.
  11. earthmover
    563
    20
    Jan 27, 2009
    i hope its not against policy.. but here you go
    www.ATSSPRINGS.com
    skippack,pa
    610-584-5428
    1-888-943-8287:biggrin_25514:
