Freightliner rear axle airbags higher than the front axle
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Shawn19, Apr 23, 2020.
  1. Shawn19
    Shawn19 Light Load Member
    117
    34
    Apr 20, 2019
    2007 freightliner Columbia my rear axle airbags are always higher than the front axle sometimes the rear are fully air up to the base wild the front axle airbags are normal i am just worry about popping one doesn't not matter if I am loaded or empty got a new leveling valve too got it in the shop a wild ago for a different issue they said leveling high an angle was where it should be i drove other freightliner Columbia before even ask my friend who has one seem like all 4 airbags should be the same high on level ground anyone ever had this issue or know how i fix it.
  3. uncleal13
    uncleal13 Road Train Member
    3,797
    6,293
    Apr 9, 2009
    Humboldt, Sk
    I've had the levelling valve go bad. It let air into the bags but would not let air out. So as I went down the highway the suspension got higher until the u-joints started to make a noise.
  4. AModelCat
    154,481
    Your leveling valve airs up all 4 bags equally.
    Look at your frame. Unless those frame rails are 100% perfectly parallel to the road, the bags on the drive axles will never 100% match in height.
    Goodysnap and pushbroom Thank this.
  5. Shawn19
    117
    34
    Apr 20, 2019
    It a new leveling valve drive ok no noise so far
  6. Shawn19
    117
    34
    Apr 20, 2019
    Not looking for 100% match on all 4 but both rear are over 1 inche in different from the front i seem even Columbia to know something it not normal
  7. AModelCat
    154,481
    4 possible answers:
    It came from the factory that way and you never noticed before.
    Ride height is too high.
    Front end is lowered (smaller diameter steer tires installed, sagged/broken front springs, wrong spacers under front springs, wrong replacement springs on the steer axle etc).
    Could possibly be a sagged pair of springs on a drive axle too.
    To start with, I'd be verifying the ride height at the steer axle is correct. I'd even park on a flat and level surface and measure the distance from bottom of frame to the ground at the front and rear of the truck. If frame is very close to level, I'd be looking at drive axle springs (assuming Airliner suspension). If frame is lower at the front of the truck, I'd be checking out the steer axle suspension.
    spsauerland, Goodysnap and pushbroom Thank this.
  8. Shawn19
    117
    34
    Apr 20, 2019
    Amodelcat that a good idea i check the high on the frame an see .
  9. spsauerland
    spsauerland Road Train Member
    4,296
    10,886
    May 31, 2010
    West Harrison, In
    Is bottom of bag tilting? Air Liner is bad about having loose/stretched u-bolts.
    pushbroom and AModelCat Thank this.
  10. Chubby Fly
    Chubby Fly Medium Load Member
    569
    796
    Nov 25, 2019
    Love that terrible noise
  11. Shawn19
    117
    34
    Apr 20, 2019
    I also have airbags on my steer axle too
