Freightliner leaking coolant on the bottom left of the Radiator
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Iclaxton2023, Jun 9, 2023.
  1. Iclaxton2023
    Iclaxton2023 Bobtail Member
    Jun 9, 2023
    I have a 2015 Freightliner cascadia it is a dd13.
    my driver called saying it was leaking at a fast rate. Luckily he got the truck back and I took a look. All of the hoses are tight and no leaks or cracks there. The top of the radiator is not cracked. I looked near the bottom left and it was POURING coolant out of the plastic trim along the radiator. Only along the bottom and I saw small drips coming out of the sides of the radiator.
    Will I need to replace the whole radiator or is this a valve issue? (My picture is very dark but is displaying coolant dripping out of the bottom left corner)
  3. BoxCarKidd
    BoxCarKidd Road Train Member
    4,418
    6,431
    Aug 26, 2014
    Your pictures do nothing for me. We used to have a good radiator shop around here. The end caps could be purchased from Freightliner. They would repair and test them.
    Now we just buy new ones.
  4. Big Road Skateboard
    5,687
    29,608
    May 2, 2021
    Yep. Cheaper to R$R a radiator. Back to work fast
    Rideandrepair Thanks this.
  5. Iclaxton2023
    Jun 9, 2023
    What exactly is R$R? I’m going to be completely honest this is my first truck and I’m just trying to figure all this #### out without the mechanics charging me for everything.
  6. wichris
    wichris Road Train Member
    4,243
    8,447
    Jan 17, 2011
    Remove and replace (R&R)
    Bottom mounts wear out and the radiator hits the frame. Common with them, just replace it
  7. Iclaxton2023
    Jun 9, 2023
    Thank you! Was hoping in didn’t have to replace the whole thing but I will just get it done!
  8. thillr1
    thillr1 Bobtail Member
    5
    4
    Jun 14, 2017
    Northern Kentucky
    Did you get this repair finished? If so how much was the radiator and labor hours?
