Freightliner FLD year 94 dont stat and sotp
Discussion in 'Freightliner Forum' started by Vaneser, Mar 3, 2014.
  1. Vaneser
    Vaneser Bobtail Member
    4
    Segovia , Spain
    Freightliner FLD120 year 1994 12.7 detroit my starts and stops:
    I invite you to watch a video recording to youtube to see if someone can help me.
    Not if I press both buttons to start and the override or only to start.
    After the engine starts and immediately stops, diesel installation is disconnected and fed only with a bottle of diesel directly to the pump is behind the compressor.
    Can someone help because the truck is in Spain, not many people know how these trucks work.
    Thank you very much.
    The video is this:
    https://www.youtube.com/watch?v=KtOWi_ebZm0&feature=youtu.be
    I do not speak English well and this is translated by google, sorry.
    We have tried to launch seven years after this standing, we have only connected a bottle of diesel to pump directly but very bad sound starts and stops, the oil level is fine, the antifreeze also.
    But after many attempts I was left by not doing harm to the engine, here in Europe the trucks run on 24 volts and this in particular is at 12 volts, but not how many battery leads and that power each, so we tried two of those here but 12 volts and turns right.
  3. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,211
    Jan 7, 2013
    It sounds like the Jake brake is stuck on.
  4. Vaneser
    4
    Segovia , Spain
    Ok thank you very much, I will continue investigating.
    At switches 2 and 4 cyl should be up or down?
    As I can disconnect the jake brakes
  5. GrapeApe
    2,215
    2,211
    Jan 7, 2013
    Of you have 2 switches labeled 2 and 4, then both should be down (or off) to shut them off. You may also have an on/off switch on the shifter.
    It should not matter to start, they should not operate at an idle. I think your problem may be mechanical, since the ECM should not allow them to come on at idle. You may have a Jake solenoid stuck open.
    If a solenoid is stuck open, then disconnecting the switches wont help. As a test, you may be able to back the Jake adjustments all the way off. That should prevent them from coming on. I don't know if they will back off enough to prevent them from coming on completely though.
