Freightliner Fault Codes
Discussion in 'Freightliner Forum' started by timtrucker1, Dec 18, 2014.
  1. timtrucker1
    timtrucker1 Bobtail Member
    13
    May 13, 2013
    Hey Guys and Gals,
    I have these codes on the dash
    ENG0
    CABB33
    CHS71
    EEC61
    I drive a 2012 Cascadia.... 420,000 miles
    What do each of these codes mean?
    Thanks
  3. FLATBED
    FLATBED Road Train Member
    Likely get a lot of response if it was posted in the GARAGE section and not under REPORT A BAD TRUCKING COMPANY
    Mattnatti and Lonesome Thank this.
  4. snowlauncher
    snowlauncher Road Train Member
    1,230
    2,599
    Mar 28, 2014
    Southeastern ID
    I'm not a mechanic and don't pretend to be one, but from personal experience driving both a '12 and a '13 Cascadia, I had a few intermittent code faults. I notified my shop and was told that Cascadias do that from time to time. After a few times shutting the engine off and starting again they would clear. As long as the gauges were reading good and nothing on the motor was loose, leaking, or missing, I was told not to worry about it...IDK.
  5. Chip S
    Chip S Light Load Member
    200
    104
    May 27, 2013
    Texas
    You are missing numbers for your fault codes. The numbers you are posting are just the source address for your different ecu's in the truck.
    eng0 is either ecm (cummmins) or mcm (detroit)
    cab33 is a fault in your sam cab
    chs71 is a fault in your sam chassis
    eec61 is a fault in your aftertreatment control module
    cab29 Thanks this.
  6. timtrucker1
    13
    May 13, 2013
  7. timtrucker1
    13
    May 13, 2013
    Ok... I guess I wont worry about it either.....Thanks
  8. timtrucker1
    13
    May 13, 2013
  9. Chip S
    200
    104
    May 27, 2013
    Texas
    You may want to get your eec61 code checked. If you have a def problem, you could run into a severe engine derate
  10. tj9281
    tj9281 Bobtail Member
    14
    Jan 19, 2015
    The chassis code is usually a light somewhere. Not always, but thats what it usually is. Ive been told it can go off if a trailer light is bad as well, doesnt make a whole lotta sense, but i guess its possible.
  11. mhyn
    mhyn Road Train Member
    4,255
    4,510
    Dec 29, 2008
    Northridge, CA
    each of this codes must have sub codes. write them and I will tell you exact problems. I have the code chart for 2012 Cascadia and if you are o/o I can share it.
    1fixitman Thanks this.
