Freightliner dome light won't turn off
Discussion in 'Freightliner Forum' started by TheLittleGuy, Mar 18, 2015.
  1. TheLittleGuy
    TheLittleGuy Medium Load Member
    389
    64
    Apr 13, 2008
    Nashville, TN
    I apologize if this has been asked before. So the big dome light at the top of the condo (behind the big curtain) and the one above the top bunk came on, in the middle of the night, on their own and won't turn off. They're wired together from the factory. The switch on the dash and the one in the bunk area do nothing.
    Anyone had this happen on their truck and get it fixed? I'm not under warranty and trying to avoid a huge diagnostics bill.
  3. orangepicker
    orangepicker Road Train Member
    1,159
    679
    Nov 9, 2011
    florida
    have you check to make sure your alone?
  4. joseph1135
    joseph1135 Papa Murphy
    11,340
    27,299
    Nov 8, 2009
    The Highway To Hell.
    The boogeyman is real!!!!!!!!
    25(2)+2 Thanks this.
  5. BigBluePeter
    BigBluePeter Heavy Load Member
    705
    826
    Aug 8, 2009
  6. mhyn
    mhyn Road Train Member
    4,255
    4,510
    Dec 29, 2008
    Northridge, CA
    I can help you if you are an O/O and don't afraid to mess with digital circuits. ))) FYI dome light gets the power from SAM CAB. Sam Cab gets digital signal from digital switches...Do you want the schematic diagrams ? ))
  7. okrancher
    okrancher Bobtail Member
    8
    Dec 29, 2011
    Central,OK
    It sounds like Murphy has gotten into your sleeping quarters.
    It might be a corroded wire in the switch(s) which is not letting the contact break. Not being sure about this, but your symptom seems like the same thing that can happen with 3-way switches in a house....you know, where you can turn off the bedroom light with a switch in the bedroom or in the bathroom... What I would do would be to pull these two switches on the dash and bunk area that you say do nothing...take a picture of them and disconnect the wires at the terminals....marking each wire and terminal....also determine which wire is the hot wire. Then, touch the hot wire to one of the two other wires to see if the cab light comes on....or not. Do it at each switch. It sounds like you have a faulty switch....which you should replace, otherwise Murphy will stick around and cause a problem later that could be costly.
    BigBluePeter had a good suggestion....sometimes the door switch needs to be readjusted. A good knock will do it...but sometimes that switch gets worn and needs to be replaced or adjusted so that the contacts open when the door is closed.
    If push comes to shove and you can't get the cab light to turn off....take out the bulb.
  8. mhyn
    4,255
    4,510
    Dec 29, 2008
    Northridge, CA
    in the bedroom or bathroom, In the century or Columbia we don't have digitally controlled circuits.
    First of all we need to understand power comes from SAM CAB because SAM CAB is #####* up or the one of two switches are sending signals to SAM CAB to power the lights. The switches are not regular switches. They have logic board in there. I would check to see if there is any active code related to SAM CAB. If there is a fault code that could indicate where to look for trouble. Next step would be unhooking one of switches and see what is happening. If in some point you have turned off lights then trouble can come from that switch. last thing would be disconnecting the wire from SAM CAB.
    But if you have an DiagnosticLink or ServiceLink software you can diagnose it within 5 minute by manually activating or turning off the light from your laptop. The software would show you actual status of switches too..
    Best regards
  9. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,211
    Jan 7, 2013
    Everything you are syaing is true if it has a SAM CAB. But, shouldn't we verify what year/model the truck even is 1st? You're probably right, but there are still many Pre-SAM Freightliner trucks out there. Never assume.
  10. TheLittleGuy
    389
    64
    Apr 13, 2008
    Nashville, TN
    Who is SAM Cab?
  11. TheLittleGuy
    389
    64
    Apr 13, 2008
    Nashville, TN
    Replacing both rocker switches did nothing. the door switches work fine. they are only connected to the front seat overhead work lights and the door lights.they are not connected to the dome lights at the top of the condo! by the way, its a 2012 Coronado. not a glider kit.
