Been having issues on a 2015 cascadia with 475k the past three weeks with the after treatment system. I’ve been at the Detroit dealer in Omaha three times and had to be towed to the Freightliner dealer today in North Platte.
The codes it’s thrown recently are spn-4357 fmi-4, spn-3510 fmi-4, and now spn-5246. The Detroit shop has replaced the doser valve, line heater, pressure sensor, and ECM. Any ideas?
Freightliner DD13 after treatment
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by runningman0661, Mar 10, 2019.
Are those codes the same as before the dealer started working on your truck or were they able to fix some of the codes??
Spn 3510 is your main problem, and it’s wiring problem with one or a couple cable that are broken or corroded.
So this last visit to the dealer in North Platte because of only one code right, spn 5246?? What’s fmi at the end??
So currently just one code for spn 5246??
runningman0661 Thanks this. -
On many Freightliner dash read-outs it list the FMI # number as FAIL #. The FMI/FAIL will lean it toward a wiring issue, sensor reading high/low, etc
Newto Trucking Thanks this.
