Freightliner Columbia Cabin tilted to the right.
Discussion in 'Freightliner Forum' started by Verdel, Jan 7, 2014.
  1. Verdel
    Verdel Medium Load Member
    596
    135
    Oct 26, 2013
    The cabin is tilted to the right, I already put new shocks and new air bags, but no change. Next I will try to check the front hinges (bushings). What else could be the problem? I measured the driver's side cabin shock and it is sitting lower than the passenger side.
  3. Hardlyevr
    Hardlyevr Road Train Member
    3,270
    2,538
    Jul 30, 2009
    Mapleton Depot,PA
    Look at the air bags, is one inflated more than the other, or positioned differently?
  4. Verdel
    596
    135
    Oct 26, 2013
    No, they are the same height.
  5. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    broken front cab mount, open hood and check it)
  6. RiskyBusiness
    RiskyBusiness Light Load Member
    95
    33
    Dec 28, 2013
    Tyner, NC 27980
    I agree, my Century had that happen. Broken cab mount.
  7. d281833
    d281833 Heavy Load Member
    881
    919
    May 15, 2012
    I had a brand new FLD 120 awhile back and it always sat funny. Low on the front drivers side, and low on the right rear frame end. Took it into the front end shop and found that the frame was twisted. Nothing serious and within Freightliners specs but always lower on one side. They wound up shimming the front left side, put a block between the axle and the spring. Fixed it no problem and like I said, went back to Freightliner and they said it was within their specs.
