Still trying to deal with sorry brakes.
What is full brake pressure on dash gauge?
How to tell if foot valve is bad?
Truck has almost no air leaks, sits for 10 hours and loss is 10 lbs.
Trailer will not keep auto slacks adjusted?? Almost need to adjust them daily.
This is very nerve racking I'm about to turn this equipment in and quit I can not stand brakes being very weak, two hard stabs and air pressure goes down to 60ish and warning comes on until I rev engine to build more. The air compressor takes 3 seconds to push my thumb off so I assume it's going out. Takes over 1 minute to build air after a bleed down test.
I can get near 90psi applied for 2 stabs at highway speed than wait a few seconds,
Than only 50 psi applied?
Replaced tractor valve in back, and primary air tank.
I'm growing upset with the owner and their mechanic.
Freightliner columbia Brake ((madness))!!
Discussion in 'Freightliner Forum' started by Oldironfan, Feb 19, 2018.
If your trailer brake adj. will not stay adj. then you must replace them with new ones! not many hills that need that much brake pressure, after you replace the brake adj. you will see a lot less air press. needed to get it stopped?
If auto slacks won't adjust, they're either shot or the pushrods are cut to the wrong length.
As for air pressure loss when you step on the brakes, have you checked the air loss with the service brakes applied? Park truck, release brakes, push brake pedal to floor and hold it there for a few minutes. Do you lose air or does it hold air pressure? If it holds, you have a supply volume issue (ie water in tanks, tanks too small etc). I believe your reservoirs need to be minimum 7x the volume of all your brake chambers combined. -
Seem to be better now. Just replaced old dryer full of water, new air compressor, governor. Otherwise it seems trailer slacks are going bad after being new 2 years ago. And next will be drive drums and shoes as they are at minimum territory.
If slacks are failing after only 2 years I'd recommend that they see grease a little more often.
Roberts450 and Oldironfan Thank this. -
Also if your drive brakes are getting low, that can make a big difference on stopping power. And your trailer brakes will work harder to make up for them. (Story time) In my early years, I had a driver who was particularly hard on brakes. At the time, I used the cheapest brakes I could find an reused drums if they looked OK. After his initial complaint of weak brakes, I change all his brake valves, chambers, and slack adjusters because his brake shoes looked fine. I ran all over that truck for a month until I did a drive wheel seal and found the inner part of his shoe was on rivets and the out sides still had a 1/4” more than the DOT line. New brakes and new drums fixed it. Fast forward 10 years, I use the hardest brake I can find, and new (but cheapest) drums every time. Same driver caught me again only this time we found it in the shop. His last set of trailer brakes we had changed to an over sea’s drum to save 10 bucks. Between the hard pad and his habits he belled the cheap drum and was again on the rivets on the inside where it couldn’t readily be seen, If my helper hadn’t notice how high on the s-cam the roller was, he never would have caught it. I’ve learned a thing or two, iwith the brake lining I run, the drum must say “made in the USA”Oldironfan Thanks this. -
The only problem with the 90 degree angle rule is that it only works if the pushrods are cut to the proper length. The auto slack adjuster is designed to maintain that 90 degree angle. If the pushrod is cut too short, the brake chamber will stroke more to reach that 90 degree angle. If the pushrod is cut too long, it will stroke the chamber less to keep that 90 degree applied angle. If you run the same truck and trailer every day and you know that the pushrod stroke is good at 90 degrees, perfect. If you're always in a different truck or do a lot of drop and hook I would not rely on the 90 degree rule to save your butt. DOT won't care and will probably ticket you.
The only blue ones I’ve seen where haledex. And to be honest I’ve only seen what your describing once or twice. I’m much more familiar with the Bendix (does have a button to pull out and 1/4” square to adjust) and Gunite (7/16 head that ratchets when backed off). If yours are the type I’m thinking, they run up kind of easy, then back off with an increasing drag, those may be finicky about what type of grease is used in them. May not hurt to see if there’s any literature that comes with the new ones. But I’m only guessing, barely an educated one at that....Oldironfan Thanks this. -
I forget when I started, most of the units I inherited had mis matched chamber rods and slack adjusters that had been installed by the shade trees before me. Really adjusted my learning curve.
Oh that, if your slacks at failing prematurely, and you have poor brake performance, the chamber rods may be cut to the wrong length. Brakes have there highest application pressure at 90 deg, which is why most adjusters try to hold them there.Oldironfan and AModelCat Thank this.
