Freightliner Columbia 2007 no light on the gauges
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Verdel, Nov 4, 2017.
  1. Verdel
    Verdel Medium Load Member
    596
    135
    Oct 26, 2013
    If the headlight switch is in down position (marker lights) all the gauges are lit, if I switch to up position (headlights on) - no light in the whole dash, but headlights, turn signals - working.
    Check the video. Bad headlight switch ? Where to look for this problem?
  3. Hulld
    Hulld Road Train Member
    2,882
    6,564
    Oct 19, 2015
    Upstate NY
    I had this problem with my Columbia and it was in the switch contacts.
    I was actually able to take the switch apart and clean the contacts and stretch the springs a bit and make it work again.
    Verdel Thanks this.
  4. Terrell370
    Terrell370 Bobtail Member
    I have a 2006 freightliner columbia smart shift and it reads PD and won't start. I pulled over last night and when I turned the truck off, it wouldn't cut off, I actually took the key out and it still was restarting itself. It finally cut off and I woke up with the PD ON the screen. I tried the codes to restart it but it didn't work. On the dash the check transmission light is on and the engine protect keeps flashing. Can anybody help me??
  5. Verdel
    596
    135
    Oct 26, 2013
    Start your own thread, don't hijack.....
  6. wtokhi
    wtokhi Light Load Member
    251
    115
    Nov 3, 2017
    did you put the display switch all the way up?
  7. Verdel
    596
    135
    Oct 26, 2013
    Did you watch the video?
  8. 07Century
    07Century Bobtail Member
    Hey Verdel i know this is an old thread, but were you able to figure out what the actual problem was? My 07 century is doing the same thing.
  9. ephy
    ephy Bobtail Member
    22
    7
    Oct 12, 2018
    Auburn
    Have you found a solution? My 07 Cdntury is doing the same thing
