Freightliner Century 1999 I can't idle up......
Discussion in 'Freightliner Forum' started by PupaINC, Jul 3, 2020.
  1. PupaINC
    PupaINC Bobtail Member
    18
    9
    Aug 23, 2013
    When running cruise control works fine. But I can't idle up. This is happening after super 10 speed transmission swapped to 13 speed. No codes. Nothing.
    Any idea? Thanks!
    Roman
  3. Hulld
    Hulld Road Train Member
    2,882
    6,564
    Oct 19, 2015
    Upstate NY
    If there is an issue with your parking brake switch it will not idle up.
    Or if you forget to apply the parking brake it won’t idle up
    PupaINC, QUALITYTRUCK and jamespmack Thank this.
  4. jamespmack
    213,429
    ^^^^ he is more than likely correct.
    Just gonna add, if it has optimized idle option from factory. It has a mercury switch on the hood. It tells ecm that hood is closed for automatic start. Its 2 wire and you can jump it with a paperclip.
    I just can imagine a 1999 with opt idle parts still on the truck. But it's possible.
  5. PupaINC
    18
    9
    Aug 23, 2013
    I know it’s unbelievable but. Yes, there’s opt idle on the truck. and it was working until trans swap. I did apply my parking brake. Maybe there’s issue with transmission harness? But speed sensor is working fine. I already tried to jump brake switch. Nothing. It’s weird, coz everything’s working fine when I’m driving.
    jamespmack Thanks this.
  6. jamespmack
    213,429
    You need to get a prolink and plug in and see what sensor isn't communicating. There are like 6 sensor idk. Last time I really work on opt idle was 2005. Trying to recall everything.
  7. jamespmack
    213,429
    Does it have 1 speed sensor but two plug and 4 wires in sensor?
    Try switching plugs. Seem to recall this happening after someone would do a clutch job and mix up plugs.
    650cat425 Thanks this.
  8. blairandgretchen
    13,225
    70,373
    Dec 9, 2011
    South west Missouri
    Did the opti idle have a neutral safety switch on the old transmission - ?
    650cat425 and jamespmack Thank this.
  9. jamespmack
    213,429
    I forgot about that one. Not at home. I cant pull out my dusty detroit bibles.
    How you been Sir? Hope all is well.
    650cat425 and blairandgretchen Thank this.
  10. PupaINC
    18
    9
    Aug 23, 2013
    I don’t know about safety switch. But harness to the old transmission had 4 connections and this one rtlo18913a only 2. So we didn’t connect solenoid harness (3 wires) and some 2 wires connector.
    Old transmission was
    FRO16210C
    We did try to switch connectors. Thank You for helping!
  11. blairandgretchen
    13,225
    70,373
    Dec 9, 2011
    South west Missouri
    Good, thank you! A little quiet lately and back on general freight to keep me busy.
