Freightliner Cascadia Tie Rod and Drag link
Discussion in 'Freightliner Forum' started by Dennis_Dennis123, Oct 2, 2023.
  1. Dennis_Dennis123
    Dennis_Dennis123 Bobtail Member
    Oct 2, 2023
    Hi guys, after how long will you need to change your tie rod and drag link? Do you guys usually change it yourself? Is there any aftermarket brand you guys can recommend for me?
    Thank you so much.
  3. SWM_TECH
    SWM_TECH Light Load Member
    139
    145
    Apr 15, 2018
    I would inspect for wear of drag link and tie rod when you service the truck and of course at your annual inspection.
    Simply, have another person turn steering wheel back and forth and watch for movement at your drag link joints and tie rod ends. Shouldn't take more than one minute. If you get to point where you start to see movement, then change it. If you are checking every couple months at services it would be plenty sufficient to catch wear before it would be unsafe. If inspecting when you do a service, inspect for movement before you grease the joints.
    In the rust belt often tie rods are getting changed because they are rusty in the threads and aren't able to rotated to adjust the toe of the steer axle, rather than being worn out at the the joints. I am coming from more a mechanic's perspective and would curious what truck owners experience has been.
  4. Big Road Skateboard
    5,684
    29,575
    May 2, 2021
    Use a big pair of channel locks and try to squeeze from the bottom of the tie rod end to the top of the knuckle. If it moves up and down, it's bad.
    Yes, easy to change yourself. Nowadays you can even buy the whole assembly together.
    Remove the nut and hit the side of the knuckle with a small sledge a few times. They usually just fall out.
    You'd still need to set toe
  5. Dennis_Dennis123
    Oct 2, 2023
    Thank you so much guys, do you by any chance, have any online link of the whole assembly that you could share with me? just for reference.
    Rideandrepair Thanks this.
  6. Big Road Skateboard
    5,684
    29,575
    May 2, 2021
    Don't have any reference for parts. Dealer of course with VIN, or get the axle code and call Fleetpride, TruckPro, ITP, etc
  7. Rideandrepair
    17,198
    55,777
    Aug 8, 2015
    Keep them greased and there’s no time limit. I had one go bad on a Truck I bought at 500k. Just replaced the original on my current Truck @ 2.5 mil. Original King Pins and Tie rod ends are still good. Check all that, including steering u joint at steering box and inside cab. They used to go bad on me. I found that the newer sealed ones without a grease fitting last much longer, surprisingly. Might as well check spring bushings. Wheel end play. That just about covers everything. One bad part tends to put extra wear on the others.
    Dennis_Dennis123 Thanks this.
