Freightliner Cascadia Info
Discussion in 'Freightliner Forum' started by usus247, Feb 22, 2015.
  1. usus247
    usus247 Bobtail Member
    38
    Nov 29, 2012
    Hello,
    I currently have a 2010 freightliner cascadia and have question
    1. My headlight are to weak, I have halogen headlight not the new led headlights the older one and when I'm driving In areas were its dark and nobodies around (hwy 17/11) it's ok not the best but when you hit highways in the USA or even canada were lighting on the highway/freeway is an issue the you cannot put high bed on ur stuck with ur low rams that show you nothing! I swear if I drive with my lowbes up on i94 I'll probably hit a dear! Can anybody help me out I'm thinking of using the headlight kit and cleaning the headlight? Is that a good idea
    2. I would like to install fog lights for frght Cascadia is it easy?
    3. The windshield is a pain when you run water to clean the windshield it goes right to the side mirror and that gets dirty and fix on that?
    4. last question what's better to install the LED light bar or the two led lights?
    hope we you guys can help me out Thanks and I appreciate it
  3. usus247
    38
    Nov 29, 2012
    So HID lights are better then led ?
    also I was looking into this
    http://m.ebay.com/itm/131427979294?nav=SEARCH
    do I need anything for this and unsure when switching from halogen to led I need a conversion kit or just do a replace?
  4. freightwipper
    freightwipper Road Train Member
    9,366
    11,439
    Mar 24, 2014
    OTR
    that's the same thing as the link I posted but just "blacked out" instead.
    The LED thing you're referring to is just the "position bar"... not the actual low beam headlights themselves.
    There's tons of info online regarding all this. Just search how to do a transformation, it's not that difficult.
  5. usus247
    38
    Nov 29, 2012
  6. jbee
    jbee Medium Load Member
    664
    619
    Jun 3, 2011
    NC
    Regarding the windshield washer problem, it's common with Cascadia's for some reason. Near as I can figure, some permanently employed, cross eyed, assembly line worker at Freightliner does the install......
  7. Justin Sane
    Justin Sane Light Load Member
    92
    69
    Aug 21, 2012
    I drive a Columbia; the windshield washer sucked also. Mine did the same thing but it also didn't squirt up high enough so the windshield was always dirty at eye level. I epoxied the 'squirt' holes and then drilled two new holes; it still squirts some on the mirror but the eye level crud is gone.
    Ever checked the aim of the headlights; that might help; mine were aimed at the ditch on the right side of road. It explained how to do it in the owners manual; it helped 100%.
  8. usus247
    38
    Nov 29, 2012
    lol I true I can agree with the cross eyed worker however is there any fix fr this? Have you tried anything that seem to work out? I hate having to bend my neck every time it snows or its salty on the road. Also I don't have the owners Manuel so could you possibly help me with what to do with the lighting problem thanks
  9. 25(2)+2
    18,749
    45,384
    Sep 18, 2006
    the road less travelled
    I don't know that there is a fix to the washer issue, but it has been addressed on the newest trucks. The 2013 still gets the mirrors wet, and I deal with it by using Rainex, (water beads off)and avoiding the washer at highway speeds.
    I usually hit it when I'm slowing below 35 on a ramp.
