Freightliner cascadia dd15 fault 520342 fmi17 any idea?
Discussion in 'Freightliner Forum' started by Wes777, Nov 6, 2020.
  1. Wes777
    Wes777 Bobtail Member
    Freightliner cascadia dd15 fault code 520342fmi17 any idea?
  3. SWM_TECH
    SWM_TECH Light Load Member
    139
    145
    Apr 15, 2018
    I am not seeing a spn 520342 fmi 17 fault in Troubleshooting manual for EPA 07, 10 or GHG14. Looking at manual for GHG17 don't see it either. Can you confirm the fault again and what year is your truck or what is the last 6 digits of your VIN?
    RocketyMan Thanks this.
  4. RocketyMan
    RocketyMan Medium Load Member
    549
    336
    Jun 5, 2015
    Can't find it neither btw...starting to lose patients with these one-post thread starters...
    AModelCat and QUALITYTRUCK Thank this.
  5. QUALITYTRUCK
    1,801
    1,762
    Jun 14, 2009
    romulus,mi
    Definition of a "Troll" Posting on multiple forums until some one gives them the "$15/15 minute fix" or all replies are the same for the fix.
    AModelCat and RocketyMan Thank this.
  6. RocketyMan
    549
    336
    Jun 5, 2015
    Gotcha...seems to make sense. I guess I just have a different version of "troll" in my head. Hehe...
    QUALITYTRUCK Thanks this.
  7. Sub Par Coffey
    Sub Par Coffey Bobtail Member
    I have the same fault code. 2018 Cascadia, DD15.
    VIN 3AKJHHDR4JSJX8057
    No reason to think anything is wrong minus a slight smell of exhaust filters and the code. Everything else is normal. Won't let me force manual regen through the display.
  8. SWM_TECH
    139
    145
    Apr 15, 2018
    520342 FMI-17 DEF System Rationality DEF pump Speed High
    Quick search showed some discussion last year of some trucks with that issue but fault solution had not been developed yet. Kind of looks like def pumps were being replaced under warranty without much extensive testing. Recommend you take it to the dealer.
    QUALITYTRUCK and RocketyMan Thank this.
  9. RocketyMan
    549
    336
    Jun 5, 2015
    520342/17 -- DEF System Rationality DEF Pump speed high
    Need DLink to run a SCR ADS Self-check routine. There could be an issue where the pump is perhaps being introduced to cavitation causing the pump to spin up faster. Maybe check for leaks on DEF header, lines, and/or pump.
    SWM_TECH and QUALITYTRUCK Thank this.
  10. 8withaV
    8withaV Bobtail Member
    11
    4
    Nov 5, 2019
    I have a 2020 Cascadia. Last night as I finished my shift, the same code 520342 17 came up with an MIL. No CEL, would it be safe for me to drive 700 miles back home? Or should I get it checked out immediately. I don't want to derate on the side of the road.
    I appreciate any input
  11. xsetra
    xsetra Road Train Member
    5,094
    6,941
    Aug 21, 2011
    My experience was with a different code, 3226 fmi 20. I've only been driving a 2017 dd15 Cascadia since February last year. I've tried to read as much as I can find about the emissions.
    If you derate, there are ways to bypass to drive to a shop. Not needing a tow truck. Also, I've read if you derate to 55 don't turn motor off, it might derate to 5. Search videos for explanation.
    I was told by a Dealer tech. That if the MIL comes on without the CEL it's not an immediate concern. Well, he didn't have an immediate concern, I did. I drove the truck for another 1000 miles the light went out, code disappeared. 10000 miles later the code reappeared, I went to a shop then because I was close to home.
    I would drive home without a CEL.
    Good luck
