Freightliner Cascadia Coolant Leak
Discussion in 'Freightliner Forum' started by B$moove2U, Mar 31, 2019.
  1. B$moove2U
    B$moove2U Bobtail Member
    Need Some expertise. I’ve been dealing with a off and on coolant leak for over a year. I have had multiple techs search for a leak but come up empty each time. I’ve had coolant pressure test done with no leakage. The coolant leaks under the driver side fuel tank. Sometimes when I park on level ground, the truck doesn’t leak but other times it will after sitting a day. I’ve parked it on inclines and declines and at times it will never leak but other times it will. I’ve had shops try almost everything but nothing has cured the issue. Sometimes I have to put 2 bottles of coolant in my truck due to leak. Where the hell could the coolant be leaking out of? The only thing that seems reasonable is the coolant is leaking from somewhere connected to my thermoking apu. There’s no coolant in the fuel neither so I’m baffled. I just wake up or arrive to my truck with a small puddle of coolant under the driver side portion of my cab below the fuel tank. Again I’ve done pressure line tests and nothing comes out anywhere.
  3. truckdriver31
    6,989
    8,352
    Sep 18, 2013
    its the two plastic coolant lines from air compressor to block on the drivers side. they are very known issues
  4. roshea
    roshea Road Train Member
    Yes, it is either one of those two hoses, or the valve on top of the DEF tank. Look on top of the DEF tank and if it is wet there, that is the problem. If not then almost guaranteed it is one of the other two lines that also routinely go bad. Do yourself a favor and replace both at the same time, they don't cost much and only take a minute to replace.
    jacobstarowski and B$moove2U Thank this.
  5. Espressolane
    16,986
    102,420
    The factory ac/heat unit for the bunk is also on that side. Bottom of cabinets, just behind driver seat.
    Possible that the heater core or lines could be leaking.
    B$moove2U Thanks this.
  6. ast26909
    ast26909 Medium Load Member
    408
    264
    Mar 1, 2018
    Good info here, you can also use coolant dye to check for this kind of leak.
    Please move this tread to Freightliner forum.
  7. uncleal13
    uncleal13 Road Train Member
    3,797
    6,293
    Apr 9, 2009
    Humboldt, Sk
    My sleeper heater core leaked in that exact location. Easy to change. They are only made of plastic-aluminum and prone to leaking. Two months after I changed it, the front one went too.
  8. uncleal13
    3,797
    6,293
    Apr 9, 2009
    Humboldt, Sk
  9. B$moove2U
    How do I move it? I’m new to this site, well posting questions that is.
  10. ast26909
    408
    264
    Mar 1, 2018
    Anyone knows the part numbers for these 2 hoses? I tried to look them up on dtna but can't seem to find them, searched for coolant hose and only heater hoses come up. Also are they difficult to replace? I notice coolant leak in this area today just want to prepare if truck has to be down for a day or two.
  11. truckdriver31
    6,989
    8,352
    Sep 18, 2013
    just call a dealer, get part number, then call truck pro
