Freightliner Cascadia 2013 dd13 Turbo replacement
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Eric5220, Jul 8, 2022.
  1. Eric5220
    Eric5220 Light Load Member
    72
    25
    Mar 23, 2021
    Sunday I’m replacing my turbo. Any tips Would help. I never did it but it doesn’t look hard so I’m going to take it off Sunday so I’m just trying to get any suggestions on what to expect or certain ways to do it. Freightliner Cascadia 2013 dd13
  3. lester
    2,914
    7,842
    Jan 2, 2012
    NW, Iowa
    Would be mildly helpful if we knew what kind of truck and engine you were working on
  4. Big Road Skateboard
    5,698
    29,729
    May 2, 2021
    Pre lube it. Put clean oil into the oil supply till it runs out the drain side. If VGT, you've got some lessons coming.
  5. Eric5220
    72
    25
    Mar 23, 2021
    I’m sorry I forgot to put that . Freightliner Cascadia 2013 dd13
  6. armo
    armo Light Load Member
    274
    290
    Jun 16, 2022
    i have changed many of them . Worst scenario is buying center section of exhaust manifold. its around $500. Do not use wd40 on bolts, use Kimball's Torq CB.. Let us know how many bolts you have cut inside. Using flame torch maybe usefull ..
  7. armo
    274
    290
    Jun 16, 2022
    its not a vgt turbo
  8. D.Tibbitt
    141,117
    What are some things u run into when replacing vgt turbo?
  9. armo
    274
    290
    Jun 16, 2022
    sometimes you need to adjust the rod like on series 60 14L engines... nothing hard..
  10. armo
    274
    290
    Jun 16, 2022
    here is the worst scenario of turbo replacement of DD15. One of behind bolts was cut. DD 13 is similar..
    20210703_092632.jpg 20210703_092642.jpg 20210703_092646.jpg 20210705_061721.jpg
  11. Eric5220
    72
    25
    Mar 23, 2021
    So I might have to cut some bolts ?
