FREIGHTLINER CASCADIA 2013/DD13 Fuel Pump
Discussion in 'Experienced Truckers' Advice' started by Captain23, Feb 20, 2021.
  1. Captain23
    Captain23 Bobtail Member
    16
    8
    Feb 20, 2021
    Hello,
    I recently purchased a Freightliner Cascadia 2013 DD13 Engine. I’ve had the truck for 2 days & recently went to my local mechanic to do a PM Service. After doing so the truck had trouble starting, I understand certain. Times air can get into fuel lines of truck if filters were put on improperly. After 30-45 minutes we finally got the truck running and changed the filters again. It still gave some trouble but eventually it became steady. My mechanic told me my fuel pump is weak and it shouldn’t have taken that long for the truck to turn back on.. I purchased this truck from Penske. The truck has low miles and was a leased to a local customer throughout its life span. What can I do to make sure my fuel pump is isn’t bad? Any troubleshooting or advice l. Any beneficial advice would be really really appreciated!
    TRYING TO
    KEEP IT MOVING!!
  3. Moosetek13
    Moosetek13 Road Train Member
    14,527
    18,010
    Nov 1, 2010
    Burnsville, MN
    "What can I do to make sure my fuel pump is isn’t bad?"
    Have it tested, or simply replace it with a new unit.
    "My mechanic told me my fuel pump is weak..."
    Did he actually test it?
    And if he did and found a problem, why was it not replaced?
    Maybe you should find a different mechanic?
    MOBee and Captain23 Thank this.
  4. Captain23
    16
    8
    Feb 20, 2021
    Appreciate feedback.
  5. uncleal13
    uncleal13 Road Train Member
    3,797
    6,293
    Apr 9, 2009
    Humboldt, Sk
    There is a manual hand priming pump on the fuel filter housing.
    Just pump it somewhere in the neighbourhood of 150-250 times, try to start for only five seconds. If not, pump it more, should get some resistance this time. should fire up.
    Don’t just lean on the starter, the fuel pump will run dry. It requires fuel to lubricate it.
    Also NEVER change the oil and fuel filters at the same time. Do one, start the truck. Then do the other. Engine can sieze.
    Captain23 Thanks this.
  6. Ridgeline
    22,116
    113,354
    Get another mechanic, sounds like a parts changer and will just take your money.
    take it to the dealer.
  7. BackwoodsGA
    BackwoodsGA Road Train Member
    1,923
    9,784
    Mar 18, 2012
    Elgin Nd
    Replace fuel pump for peace of mind.
  8. snowwy
    snowwy Road Train Member
    20,527
    13,262
    Jul 6, 2009
    Doesn't the fuel pump turn on with the key. Builds pressure then shuts off waiting for the engine to fire up.
  9. Antinomian
    Antinomian Road Train Member
    2,078
    3,243
    Feb 17, 2013
    $1250 dollars, plus about four hours labor.
  10. Antinomian
    2,078
    3,243
    Feb 17, 2013
    The fuel pump has a priming port. A good shop will have a priming pump. You can't say the pump is weak just because the mechanic didn't know how to prime it or didn't have a priming pump.
    Did you find metal in the fuel filters? The DDDL software will show how much pressure the pump is generating and that is the next place to look if you suspect it is failing. I wouldn't suspect that if the truck starts and runs OK now.
  11. BackwoodsGA
    1,923
    9,784
    Mar 18, 2012
    Elgin Nd
    I keep forgetting 60 series is no more..days forever gone.
