Freightliner BUSINESS CLASS M2 106. Cant find the answer
Discussion in 'Experienced Truckers' Advice' started by Gonzo1300, May 23, 2014.
  1. Gonzo1300
    Gonzo1300 Light Load Member
    237
    113
    Sep 30, 2013
    I cant seem to find the answer to the question. What kind of miles are the Freightliner business M2 drive trans getting? I see some with 150,000 and some with 300,000. I know most dont start sweating in a class 8 untill 800,000
    [h=1][/h]
  3. CondoCruiser
    CondoCruiser The Legend
    19,726
    18,733
    Apr 18, 2010
    Tennessee
    It's safe to say 500,000 miles. A well taken care of ISB can reach 1,000,000.
    Which engine does it exactly have? They make like 3 different ones for them trucks. Then you have to consider the axle weight to see how hard the truck might have worked. If you are serious on one have a mechanic check it out and run an engine oil analysis if it hasn't been recently changed. Most engine repairs start about 250,000 so you have to consider that. One with 300,000 might be someone else's problem or it might have new parts.
  4. Gonzo1300
    237
    113
    Sep 30, 2013
    It was bought by the company I work for new. This one is plated for 50,000 axle was 9500 and 17,000. The loads it run advarage around 40 gross. I was thinking of buying a used one with around 100,000 on it. Reason I was asking is b/c I dont know much at all about these smaller trucks. It has the cummins in it, Im pretty sure it was ISX
