First off, if this is on the wrong board, by all means, mods move it where it belongs.
Now to the meat and potatoes. I have a Freightliner FLD with an under the cab airhorn. Inspected and checked. Oldie but functional and makes money (the truck, not the horn.)A problem sprung up recently (today to be precise). Air horn no longer turns off until the air pressure drops to the warning buzzer. Any suggestions? I'm parked for the week, so its a good thing, but I want to fix it myself if I have to. I can't drive to a shop at the moment without the horn driving me nuts. If it turns out to be something I can fix, I find the idea entirely acceptable. I'd prefer not to pay for the tow truck at this point in time.
So, that said, suggestions, advice, anyone?
Freightliner air horn issues.
Discussion in 'Trucks [ Eighteen Wheelers ]' started by ppc, Nov 18, 2009.
replace the pull valve (you know, where the cord hooks up)
other than that take the airline off, fold it in half and tape away -
If you want to get it to a shop, just use a wrench (prob 9/16) to disconnect the air line from the horn itself. It'll leak air, but not enough that you're compressor can't handle. The pull valve probably isn't hard to replace. If it's like the century class the hardest part is getting the molding panels off to get to it. If you can, then just go to any dealer with your VIN and they should have or can order it for you in a couple days. -
10-4, will do. Thank you gentlemen.
I will post my results once done.Last edited: Nov 18, 2009
Update.
It turns out that the valve was corroded. I have had some experience doing gas fitting and air conditioning so a bit of flexible tubing and some thread sealing work was not exactly unfamiliar to me. Getting a replacement valve was the order when solvent could not break loose the crud buildup enough for a replacement spring to actually operate the valve. After several hours on the internet and telephone, I found a place that had the right valve in stock and the rest is history at this point.
So, problem is now resolved. Thank you all for the help.Last edited: Nov 29, 2009
Great to hear! Feels good doing it yourself doesn't it?
Hello I have a 2006 frightliner classic and it only starts when I press horn You know what the problem is?I put on a new starter.I put on new salinoi.D I put on a new switch
