Freeing up stiff landing gear
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by 04 LowMax, Mar 18, 2018.
  1. 04 LowMax
    04 LowMax Medium Load Member
    440
    250
    Feb 3, 2013
    Alberta
    Searched all the forums on this, found nothing. My own trailers, super b, the landing gear on the pup is very stiff. Can crank in low gear only high out of the question. Trailers are less than 3 years old. Pup never gets unhooked, so the gear never gets used. Almost never. Have greased them more than adequately so it's not lack of grease. They are holland mark V. The extendable portion moves around easily in the outer legs, so it's not the sliding portion thats stiff. Holland put a tag on the leg indicating if this situation occurs, to pull the top cap off, and pour motor oil inside. Also to keep greased of course. So I tried this today. Not a lot of improvement, maybe I just need to spend a couple hours cranking up and down? The oil did start coming out around the gear case shafts. There was lots of grease in the top of the leg where the crown and pinion gear are. I am thinking the problem must be in the threaded portion and their theory with the oil is that it will make its way down there eventually. Has anybody had any luck with freeing up stiff gear like this? Any other tricks I could try? (I did only do the drivers side with the oil so far, ran out of time for the other side today). TIA
  3. Getsinyourblood
    Getsinyourblood Road Train Member
    1,263
    1,769
    Jul 5, 2014
    Retired. North Texas
    While you are waiting for a good, qualified answer, I will tell you what I saw one time. At a previous company, I watched our trailer man working on some landing gear one day. The crank was very stiff and would hardly turn. He was pulling out hand fulls of grease out of the landing gear. He told me sometimes mechanics tend to over grease the landing gear which will make the crank not want to turn at all. I don't know if that would apply to you or not.
    Bean Jr. and 04 LowMax Thank this.
  4. 04 LowMax
    440
    250
    Feb 3, 2013
    Alberta
    Thanks for that. I could see that might be a problem if it got over packed with grease where the gears are, if it was very cold, and it was heavy grease. Not cold here now, I use low temp grease, and not over packed with grease. If I am understanding the system correctly there is a threaded rod underneath the crown gear and I'm betting that's the part that gets dry, rusted, and makes it hard to turn. I appreciate the reply. Edit, searched further, found a couple you tube videos on the subject. Think I found the answer. The lower of the 2 grease fittings is for the jack screw, which is what usually seizes up. You can pull this fitting and either squirt penetrating oil, or basic engine oil, depending on how bad seized. Let sit overnight, run legs up and down, repeat as needed til free, then grease liberally. The other trick I had forgotten about, funny how age and memory play with each other, is to pull the bolt on the cross shaft to tell which leg or both, are the tight ones. I remember now, on an earlier set of trailers, I acutally had a quick linch pin in there rather than a bolt so if I was unhooking on uneven ground I could run one leg up or down a bit as needed, so they were contacting the pads at the same time, saved looking for small spacer blocks.
    Reason for edit: Found some helpful you tube videos.
    xsetra and Getsinyourblood Thank this.
  5. ErieMcDreary
    ErieMcDreary Medium Load Member
    460
    393
    Dec 4, 2016
    Erie PA
    Check mfr's specs on what grease is required. Chassis grease will make them very hard to turn, especially in colder weather. They usually spec a very light grease.
    04 LowMax Thanks this.
  6. 04 LowMax
    440
    250
    Feb 3, 2013
    Alberta
    Yes. I use low temp/arctic grease. Same with brake slacks and cams. That's another place you don't want heavy grease.
  7. MechanixRus
    MechanixRus Bobtail Member
    I would check the reinforcement band around the bottom of the leg. It’s common for corrosion or rust to build up between the band and the case of the leg and cause the case to compress into the leg causing it to bind and be difficult to get it to go up and down. Simple fix if that’s the case, as you just cut the band bang out the rust with a hammer and weld up the band again.
  8. Luwi67
    Luwi67 Heavy Load Member
    746
    484
    Oct 24, 2012
    Long island
    Ive had both those things happen to my landing gear as in post 2 & 6. Those would be my suggestions too.
  9. Rc1234
    Rc1234 Bobtail Member
    18
    4
    May 31, 2018
    #6 ...worked for me after fighting with this problem for a while...
  10. traveling man 28097
    traveling man 28097 Bobtail Member
    5
    Sep 11, 2016
    old thread but here is a sure fire fix,grease ain`t the answer
    number 6 post in video
    Broke Again Thanks this.
