freehold cartage inc
Discussion in 'Motor Carrier Questions - The Inside Scoop' started by RJ33RD, Jan 15, 2011.
  1. RJ33RD
    RJ33RD Heavy Load Member
    857
    157
    Aug 27, 2009
    Baltimore, Md
    My friend asked me about this company and only thing I know is what their website says but does anybody know about their tanker side of things ???? They drive red trucks with fci on them !!!! Any info about their operation.... thanks !
  3. jlind
    jlind Heavy Load Member
    902
    350
    Dec 21, 2010
    Nature coast, Fl.
    When I lived in NJ they were considered a great company to work for, tough to get on with though, they do mostly HAZ-MAT so they have to be careful about driver's records I'm sure. I didn't work there but I have never heard a bad word about them and the equipment is well maintained from what I have seen. I lived near the terminal and they weren't ever in the news or anything either.
    If I was into hazmat I might give them a call but it's just not my cup of tea.
    Hope that helps!!
  4. crowhrse
    crowhrse Bobtail Member
    44
    5
    Dec 11, 2008
    Marcus Hook,Pa
    :biggrin_25522:Hello,
    I have a friend who works for them. Their tank trailers are all smooth bore,which means there are no baffles in them so you will feel the surge. Their trailers are VAC trailers which means you hook a hose up to the unit on the tractor and you can then vacum product into the trailer. Then fro unloading you can either gravity unload or reverse the the air pump to pump off the load. This is the type of trailers you will find at most if not all companies which haul hazmat material.
    FCI also has van trailers and roll off containers and I'm not sure if they have any flatbeds.
    I just started working for a company that competes with FCI in the same type of bussines and we have tankers,vans, flatbeds and roll off container trailers and straight trucks. Hope this helps.:biggrin_25522:
  5. RJ33RD
    857
    157
    Aug 27, 2009
    Baltimore, Md
    Thanks crow and jlind that info is very helpfull !!!!!
  6. KnuckleBuster
    KnuckleBuster Light Load Member
    206
    189
    Jun 20, 2010
    Wellsboro Pa, Lakeland Fl
    I worked for Freehold back in the early 90s hauling hazardous waste in roll offs. To be honest, they were way under the going rate for hauling that stuff. If you are going to get into hauling hazardous waste, I'd really suggest looking into Horwith Trucks in Northampton, Pa. They pay twice as much as Freehold for doing the same kind of work.
  7. RJ33RD
    857
    157
    Aug 27, 2009
    Baltimore, Md
    Thanks knuckles
  8. Highwaydrifter61
    Highwaydrifter61 Light Load Member
    55
    77
    May 5, 2019
    I worked for Horwith from 2015-2017. Good company. Started with frameless dumps then went to rolloff. Made good money there. I've got nothing bad to say about them. Only left because I moved out of state.
