Frame modifications
Discussion in 'Trucking Industry Regulations' started by m16ty, Feb 14, 2017.
  1. m16ty
    m16ty Road Train Member
    2,265
    4,942
    Jan 22, 2016
    All my life, we've been lengthening and shortening frames on various trucks for different applications. We've never had a problem with one of our frame mods and never been questioned by a officer about it. I wonder though, if you really got down to it, if it's legal. I think, if the modification is done right, it's not really noticeable to a inspector, which my be the reason we've never been questioned.
    Years ago, it was quite common for most truck frames to be modified at some point in it's life and rear "cut-offs" were common. If somebody wanted to change their rear ratio or their suspension or rears were worn out, they would just get a cut-off from a wrecked truck and weld it on.
  3. blairandgretchen
    13,212
    70,210
    Dec 9, 2011
    South west Missouri
    Begs the question - just because everyone does it - is it right?
    I suppose the only test it would have to pass is a visual DOT inspection?
    Plenty of businesses that do it that may/should know - but after all, it's just an extension that can be made stronger than the original piece if done correctly.
  4. m16ty
    2,265
    4,942
    Jan 22, 2016
    Most larger businesses that do frame mods have authorization from the FMCSA to perform such mods and will add a sticker in the door jam stating as much when they do a mod.
    We've passed visual inspections by the DOT on a 379 that was shortened between the tandems and the cab. We didn't point it out though so I doubt the inspector even saw it. The only indication something has been done is a frame insert on the inside, spanning the splice. The splice on the outside is ground smooth and I can point it out because I know where it is but it would almost impossible to find in a standard roadside inspection.
  5. Chasingthesky
    Chasingthesky Heavy Load Member
    936
    1,569
    Apr 30, 2010
    Denver, CO
    Its legal if done to manufacturer specs
    393.201 Frames.
    (a) The frame or chassis of each commercial motor vehicle shall not be cracked, loose, sagging or broken.
    (b) Bolts or brackets securing the cab or the body of the vehicle to the frame must not be loose, broken, or missing.
    (c) The frame rail flanges between the axles shall not be bent, cut or notched, except as specified by the manufacturer.
    (d) Parts and accessories shall not be welded to the frame or chassis of a commercial motor vehicle except in accordance with the vehicle manufacturer's recommendations. Any welded repair of the frame must also be in accordance with the vehicle manufacturer's recommendations.
    (e) No holes shall be drilled in the top or bottom rail flanges, except as specified by the manufacturer.
    [53 FR 49402, Dec. 7, 1988, as amended at 70 FR 48055, Aug. 15, 2005]
    Toomanybikes and not4hire Thank this.
  6. Ridgeline
    22,103
    113,210
    NO! the FMCSA doesn't authorize anyone to do frame mods, the sticker is a result of them being an upfitter which anyone can be, they have to register with the state as a business and then follow the guidelines for modifications by the manufacturer. This does not include a things like frames but it includes altering the GVW of the vehicle.
    Once a mod is done, they can apply a sticker on the vehicle that says they modified the gvw of the truck - that's all it is about - and it states who they are.
    The dot will look for fatigue or damage to the frame, obvious stuff. Like cracking around bolt holes and so on, they don't really care about anything else.
