Frac sand hauling questions.....
Discussion in 'Oilfield Trucking Forum' started by drew2083, Jul 16, 2018.
  1. drew2083
    drew2083 Light Load Member
    129
    49
    Oct 14, 2017
    Colorado
    So, I'm about to start hauling frac sand for a frac sand hauling company here in Colorado. He says he will start me at 28% of each load and detention pay will be 20/hr after the first hour. Is this a good gig? By the way, I am fresh out of CDL school. I will get 14 an hour while in training.
  3. KTM042974
    KTM042974 Bobtail Member
    8
    Perfect! Good gig to get training and your foot in the door.
  4. Oilfieldmike
    Oilfieldmike Medium Load Member
    341
    159
    Aug 22, 2012
    holiday, florida
    Sounds good. Especially detention after an hour
  5. drew2083
    129
    49
    Oct 14, 2017
    Colorado
    Kinda nervous. I dont know if its worth doing. I hear that the wells are down a lot from drivers.
  6. bbq247365
    bbq247365 Light Load Member
    162
    158
    Oct 19, 2012
    Not sure what this means, can you elaborate or give context to this statement ?
  7. Oilfieldmike
    341
    159
    Aug 22, 2012
    holiday, florida
    Wells go down from equipment failure or crew failure. Frac companies are having a hard time finding experienced Frac hands because the Frac hands they had in the last boom didn’t come back when this boom started. Most took their experience into other areas. Inexperienced Frac hands with fall behind keeping the sand mixed properly or responding to sudden pressure changes. The ultimate screw up is when the sand fills up the well and they have to bring in coil tubing to get the sand out. Either way, an inexperienced or flat out bad Frac crew can turn a one month or less Frac job into several months
    If you are loaded with sand and headed to a well and that well goes down you get paid to sit until the well goes back up. My record wait time is 21 hours.
    With sandbox the well may run out of empty boxes. The sand comes in faster than they can use it meaning more paid wait time.
    If you staying in the truck with no slip seat 12 hour shifts you’ll make over $2000 a week plus easy with three runs at least per day. And that’s taking it easy.
    Either way jump all over it. Halliburton took out their company trucks meaning more jobs for the contract carriers
    speedyk and MagnumaMoose Thank this.
  8. Masonkid
    Masonkid Bobtail Member
    44
    28
    Nov 20, 2017
    Will you be in the Windsor area? Not bad. I have to wait 4 hours. I don’t get much retention pay anymore.
  9. drew2083
    129
    49
    Oct 14, 2017
    Colorado
    Yea, thats where I live.
  10. drew2083
    129
    49
    Oct 14, 2017
    Colorado
    Direct Hauling, LLC is the name of the company. He is looking for drivers.
    speedyk Thanks this.
  11. Masonkid
    44
    28
    Nov 20, 2017
    He’s added several lately I believe. I haven’t talked to any of the drivers. I see them on jobs and loading.
    Pulling for the same contractor, that’s a good deal. You should turn 3 to 4 loads average, 4-6 days a week I would guess.
