I am doing PM on my trailer today. I want to remove the hub caps to inspect the bearings, but I am out of the hub cap gaskets. Can I use the form a gasket or silicone gasket maker on these?
Form-A-Gasket on trailer hubs
Discussion in 'Trucks [ Eighteen Wheelers ]' started by silver dollar, May 28, 2012.
I never play this game. I use genue gaskets, cheap part.... Leaking fom hub oil is too expencive thing, just imagine bearing cost! and do not forget about fire danger
dairyman Thanks this. -
NEVER AGAIN. I ended up spending more $ topping off with hub oil due to a leak(didn't get a good seal with perma-gasket) than if i had just went ahead and bought the dang gasket. -
Often, the problems encountered with silicone usage are failure to clean and dry the surfaces and the buildup or accumulation of silicone in the bolt holes not allowing the bolts to fully tighten the hubcap to the hub.
A gasket is always better, but silicone can work for some things where there is no pressure on the sealed component if the silicone is used properly. All things can turn out bad when procedures aren't followed, but that doesn't necessarily mean it's all bad.
Thanks for all the replies. I normally use gaskets but it was Memorial Day and all the parts houses were closed. I noticed that all the caps had oil seeping where the sight glass meets the housing. So I did my inspection and went to the parts house today and got 4 new caps w/gaskets. Thanks again everyone.
